Has a 2.5inch vertical black line about 3/4 from the left hand side its a panasonic TH50PX80A Thank you
    President:
  • 1,099 Answers
All lasma an lcd ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 03, 2010
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
I have a Panasonic plasma TH 42PX60U model. A white vertical bar on the left of the screen...with blue...black...red thin lines inside the white bar. Do you know which part i need? Thank you. Jeff
I believe one of the chips on the signal processing board has gone bad...I hope you are familiar with hand reworking solder joints. I also hope they are not BGA chips...If they do not have visible leads, you are probably beat.
Mar 21, 2016 | Panasonic Televison & Video
Ive got a line down the left hand side of the screen when the tv is turned on the model number is panasonic viera tx-p42v20b
HI,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
May 13, 2011 | Panasonic Televison & Video
Panasonic th37px60
Just taken mine in for repair and was told this. "After checks to Switching and Data flow to PDP, Suspect the Plasma display panel to be at fault
which also may well have caused damage to the buffer and logic boards."
I am presently trying to get currys to replace it as it 18 months old.
Forgot to say was quoted £1200 to fix!!!!
May 18, 2008 | Panasonic TH37PX60 37 in. Plasma...
Techwood 42 plasma
if you still need the fix for this repost i have just repaired mine i had a 1 inch thick line just off centre .this is a easy fix no parts required.
Apr 19, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Problems with my sony kv32fx20u tv
sony kv36xbr400 wega I have a 5inch black line across top and bottom & gray side to side making a smaller picture.
Nov 16, 2007 | Televison & Video
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
