Question about Lomo Diana Mini 586 Film Camera
I loaded film into my diana mini, and i know the sprockets have a hold. but as i trun the advance film wheel, it keeps turning and turning and never stops..
SOURCE: pentax me super can not advance the film advance
all that was wrong with mine- THANK GOD is that the shutter was a little sticky! so i fixed it myself! yeah for me!
i thought it was really broken! but thanks to fixya.com i can actually FIX things instead of BREAKING them more! hahaha
thanks- this site is a LIFE SAVER!
Posted on Sep 25, 2009
cammedic
  • 667 Answers
SOURCE: jammed film advance lever
There is a capacitor that goes bad in the X series. You can find them on eBay. A simple soldering job. It is in the bottom of the camera, accessible by removing the bottom cover. (4 screws)
Posted on Feb 19, 2008
cammedic
  • 667 Answers
SOURCE: The sprocket in my Minolta
The battery holders were known for corrosion buildup at the pivot point, your batteries might not be making good contact.
Posted on Mar 04, 2008
Obertelli
  • 3006 Answers
SOURCE: Just bought my Holga 135. Whenever I load 35mm
Return the camera for an exchange or refund.
All Holgas are very badly made (which is why they produce the unpredictable image results that they're currently fashionable for) and it's not uncommon for them to be faulty from new. Also, don't expect the camera to last for more than about 12 rolls of film before it breaks: Holga specifically state that as an expected model lifespan on many of their model instructions and on some models they limit is even lower.
Posted on Jun 07, 2010
caroldon
  • 17130 Answers
SOURCE: The sprocket gear spool on
This sprocket can be JAMMED/ STRUCK OR the link broken/damaged within the drive to the motor as it MUST MOVE ALONG WITH the movement of the take up wheel.
Normally the motor drive couples the drive to the take wheel and to the winding sprockets. You will need to open the mechanism on the base of the sprocket to get access to the fault. Sometimes just a reset can change the fault. Use a degreasing spray WD40 into the ends of the sprockets and manually try to move the sprockets to both sides. ALso without loading any film , activate the switch on the door - door lock- to make the take up wheel and sprockets to turn. Assisting them might make it free , if not you will need to open the motor drive section and the gears on the base of the sprockets. Use of good tools with care and makeing a note of what is done is improtant to remove and reset this section. If some parts are damaged you will need genuiene spares.
Good luck
Posted on Sep 01, 2011
Iana mini rewind crank not spinning when advancing film
If the film is advancing you do not have a problem. It may be that the rewind button does not actually spin when you advance the film, because if it did and you have something caught on it when you are trying to do so you could really mess things up. Really, the rewind crank may only visibly spin in one direction.
Apr 17, 2014 | Lomography Diana Mini Camera & Flash...
Missing a part in my Diana F+
Sorry we have no locator services here for part of any kin.
Jun 08, 2017 | Lomo Diana F+ 35mm Film Camera
? Is the sprocket wheel in the middle of the projector supposed to move? The film seems to be locked up in there, and only the few inches of film in the gentle curve above the lens seems to feed thro
I know this post is old but I found a solution. The axle going to the sprocket is locked up with something sticky. You have take out the two screws holding the white plastic piece around the sprocket. Then loosen the small bolt on the big wheel on the other side. Remove the big wheel. Try to push the axle through to the other side. If it doesn't budge easily, hammer it out. That's what I had to do. Then clean it up real good with solvent, like alcohol. Lube it with grease and put it all back together. Worked for me.
Jul 19, 2012 | Kodak Antique Brownie 300 Movie Projector
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Jul 29, 2011 | Nikon Photography
Do i need to rewind film after taking a picture on my diana f+ ??
If you are using 120 film (medium format) you only need to advance the film as far as possible. Then remove the film from the camera and wrap the excess paper around the roll and seal.
When you finish all the pictures on the roll of 35mm film you will need to rewind the film completely before exposing it to light. You can do this by taking the camera in a pitch dark room, removing the film and turning the knob on the top of the film roll until the film has been completely wound back into the the roll.
Mar 29, 2011 | Lomo Diana F+ 35mm Film Camera
I've just loaded the film into my Canon A-1, and I tried to advance it to the first frame, but nothing seems to be catching the film, and the shutter button doesn't seem to be doing anything either. Please...
What has probably happened is that you have not yet engaged the sprockets into the sprocket holes in the film. Open the back and make sure the film is being pulled by the take up spool under the wind on lever until both top and bottom sprockets are engaged. If there are any torn sprocket holes in the film, cut the damaged film off, cut a new lead in section to half film width, and try again. You will lose a few shots, but the rest of the film will be fine. Shutter won't start working until the film is properly advanced. If you need to get damaged film off the take up spool just press the film return button, the one you would press the rewind the film into the can at the end of the film. It is on the bottom under the sprocket shaft.
Jan 03, 2011 | Canon Photography
How do i know when my battery is dead. Every time my pictures are developed, they come out black. how do i use the exposure meter?
The K1000 is all mechanical, the battery only powers the light meter. So even if the battery is dead, then you should still be getting images even if very over or under-exposed.
If the images are totally black on the negatives, then your shutter is stuck open and massively over-exposing your images. If the images are black on the prints, then the negatives have been unexposed and will be totally clear. The latter problem means that the film has not been exposed at all and is either due to incorrect film loading, faulty film winding, or a shutter which fails to open.
To eliminate the possibility of a shutter fault, hold the camera up to the light with the camera back open and fire the shutter at each setting. You should see light as the shutter opens and from 1s to 1/30s should be able to see and hear the difference at each speed.
To check film loading and advancing correctly, load a film and wind film on (remember this camera needs the film leader to be manually engaged onto the take-up spool). Use the rewind crank (do not press the rewind button) to take up the loose film and take a few shots. You should see the rewind crank turn each time you advance the film if it is correctly loaded and advancing. If not, open the camera back and visually inspect the film. It should be securely engaged into the take up spool. With the back still open, advance the film and take a few shots: the take-up spool should be advancing and the sprocket wheel (just before the spool, it's the wheel which engages the holes at the edge of the film) should also be turning. If it isn't, then the film rewind mechanism is faulty and the camera is behaving as if the rewind button has been pressed. It's usually easy to remove the bottom of the camera to check that the button isn't sticking.
If all checks so far are OK then check the film pressure plate on the inside of the film door. It should be able to give a little when pressure is applied and holds the film firmly in contact with the advance sprocket, if not then one of the seating pins on the flat metal spring may have become dislodged and it's usually easy to reseat it. Clean the plate after touching it as it must be grease-free and spotless.
If you try all this and still have a problem then please add a follow up comment and I'll try to respond asap, but bear in mind that as I'm in the UK I may be in a different time zone to you.
If I've fixed your problem, then please take a moment to rate my answer.
Aug 19, 2010 | Pentax K1000 35mm SLR Camera
Diana F+ 35mm back wont load film.....
possibly you have a friction padded roller instead of spikes place enough film on roller to overlap and then close camera
Dec 09, 2017 | Lomo Photography
Blank Film Developing
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon AE-1 won't rewind film without tearing it up.
misstigeress,
is the film being ripped along the sprocket holes? if so, the rewind button is not unlocking the drive sprocket. with film removed open the film door and push the rewind button in, the drive sprocket should turn freely. now charge the shutter with the advance lever. the rewind button should pop out and the drive sprocket should not turn freely.
if the sprocket did not turn freely with button pushed in, the camera needs repaired. there are no new parts for this model canon so any parts needed will be good used.
Nov 30, 2008 | Canon EOS-AE-1 35mm SLR Camera
Lomo Diana Mini 586 Film Camera Logo
224 people viewed this question
Top Lomo Photography Experts
Hashim Khan
Hashim Khan
Tony Parsons
Tony Parsons
Are you a Lomo Photography Expert? Answer questions, earn points and help others
