Remote control does not work, even with new batteries, does not light up. i tried taking out the batteries, pressing each button individually, (in case it locked up,)replacing the new batteries, and still it does not light up or work.
    President:
  • 1,099 Answers
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and proceed to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat to click the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keypad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develop dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to…
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo…
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h…
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons on my Panasonic VCR. Once you have completed test with your camera you can use the remote.
Thats it, I hope you got it going again
Posted on Aug 03, 2010
I bought a second hand VD player with remote, player works great but remote does not work at all, even with new batteries
Buttons on the remote control should work individually. If it is universal remote control [not the original one with the projector], you should have to set it up with its set-up codes. For more details, you have to download the manual to the remote control you have, if it is a universal one. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 24, 2014 | Televison & Video
It don't work even the battery is new
If the remote is not working,try to open the remote and check the battery terminal the one that is connected in the pcb if loosed, then if you have a cellphone with a camera, point the sensor in the camera lens then press any button, then try to look the monitor of your cellphone you will notice that their is a glowing red light it indicates that the sensor is in good condition if you do not see anything try to replace the sensor.
Jun 24, 2011 | Televison & Video
Hyundai dvd model hy-03s remote not functioning
first thing is the obvious, make sure you have brand new batteries installed. If you have a camcorder or digital camera, point it at the remote control and push record, while recording, press some of the buttons on the remote. the camera will record the red light if the remote is working (camcorders and digital cameras can see this light even though people can't) to do this with your digital camera, have somene push and hold one of the remote control buttons while you take a photo, the red ligth should show up in the photo. If you see no red light then you have a bad remote control and will need to send for one or get one ordered through the store, one other option is to buy a universal remote control and try getting that to work, good luck
Mar 16, 2011 | Hyundai Televison & Video
Remote does not work even with new batterys
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it
Mar 06, 2011 | Curtis DVD2054 Theater System
My MKJ40653802 remote won't work even after putting in new batteries.The TV is hooked up to sky and that remote works fine + the Tv works on the buttons but not on the remote.Any suggestions
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. (no light means bad remote)
If you do then the problem might not be the remote but the sensor on the set.
IF this does not work then;
you can turn the set off and unplug for about an hour to allow any EPROMs to reset. Next plug back in and try the remote.
If this does not work it
Feb 28, 2011 | LG Televison & Video
Not able to turn tv on with remote
First try changing the batteries.
Next make sure when you press function on the remote control the red light on the remote displays under tv
Next try a remote reset:
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
Aug 24, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
May 27, 2009 | JVC LT-26X575 26 in. LCD HDTV
Controler will not turn channels
If you still have the manual that came with remote, reprogram the remote for your receiver. The RC32 is has had some issues because of all the new Directv components available
Jan 05, 2009 | Directv RC32RFK Remote Control
Dish Network remote control unit malfunctioning problems
Hi Monell56 my name is Mike Houston of DISH Network, with the DISHNetwork remote and replacing the batteries in the remote you will press andrelease the SAT button and press select on the remote. If the SAT button didnot light up the remote will need to be replaced. If the SAT button lights uphere is the link that will help setup the remote. http://www.dishnetwork.com/SupportSection/remote-setup
Dec 04, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
