Question about Peg Perego John Deere Turf Tractor
How do I change the rear tires? - Peg Perego John Deere Turf Tractor
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Remove the center cap of the wheel then remove the metal push nut, then you should be able to pull the wheel off and replace it, do not pull the axle out cause there are spaces by the motor that will fall out of place, then you have to do alot more work to put it back together, if you need new wheels you can order them here www.powerwheelsoutlet.com
Posted on Jun 06, 2012
I have a wobble in left rear
could be bent axle but I would lean toward a bad tire. jack rear of vehicle qnd rotate tire slowly , if bearing is bad you will feel it. hold top and bottom of tire and rock, if bearing is bad you will have play or movement. rotate tire slowly and observe where is wobble is.
Jul 21, 2018 | Cars & Trucks
Motorcycle tire pressure
According to a fury forum the tire pressures are 33 psi for the Front
41 psi for the Rear.
Please note this will be for the original tires if these are changed you need to ask the tire manufacturer. My Suzuki had Dunlop radials at new 33psi front 36psi rear. Changed to Bridgestone and the pressures now are 36psi front 39psi rear.
Aug 23, 2014 | 2011 Honda Fury
Road noiseSounds like unbalanced wheel
If it is unbalanced, it should vibrate on the steering wheel. you should rewrite your problem and include car type, speed that it happens. Also take off any hubcaps and rotate tires front to rear and see if it changes.
Dec 19, 2013 | Cars & Trucks
Humming noise from left rear tire area tire is new could this a axle bearing problem
it could be, But I would flip the tires first ,, it could be a bad tire, switch it with the right rear and see if the noise changes
Jul 25, 2011 | 2007 Suzuki XL-7
1997 cavalier, both rear tires wearing on the outside 1/2 of the tires. What would the probable culprit be? The car has 97k miles on it...
if you don`t rotate the tires this can cause abnormal tire wear.but with tire wear on the outer 1/2 of the tire indicates either the camber setting is off or you could have bad rear springs changing the ride height of the car causing the change in camber.to find out you would have to have a 4 wheel alignment done to check rear alignment readings.if the springs are worn then the ride height can be checked with a tape measure and compared to specs,if off then the springs should be changed along with the rear shocks.
Jun 29, 2011 | 1997 Chevrolet Cavalier
Had a flat tire on my GMC Sonoma. Changed the
wheel rim damaged ?? locating pin for wheel not lined up
May 16, 2010 | 1993 Nissan Altima
How to change the rear tire on a 2007 nissen
if you look by the rear hatch lock at the bumper,there is a cutout for the tool for the winch lever to fit into.the 2005 to 2009 are all the same.
Nov 05, 2009 | 2007 Nissan Xterra Off Road
Jack position to change rear tire 98 pontiac grand prix
factory jack to be placed in front of tire inbetween notches on seem. A manual floor jack can be used placing it under center connection bracket for rear wheels. Be shure to block front tires when using floor jack and have car in gear if a manual or park if automatic transmision.
Mar 31, 2009 | 2002 Pontiac Grand Prix
WHAT KIND OF TIRE FRONT AND REAR
I have a roadliner and have the same problem,they only offer two differant bad tires for our bikes,the dunlop and the bridgestone,you could bump up to a 200/55/17 it will fit and wont change the geometry of the bike.I have been waiting for avon to make tires to fit the bike.I havent heard of the conversion to an 18in tire,will have to look into this.
Mar 31, 2009 | 2006 Yamaha Stratoliner S
Where do I put jack when changing rear tire
Put on e-brake and place jack under rear axle on the side of the wheel as close to it as you can
Nov 27, 2008 | 1999 Ford Ranger SuperCab
Peg Perego John Deere Turf Tractor Logo
81 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
