Question about Sony Cyber-shot DSC-S700 Digital Camera
Does not stay powered up
When you turn on the camera, the lens goes in and out and then the camera turns off. You can refiew pictures and the icon says that the batteries are full, we just recharged them. You cango into menu and play all you want, but as soon as you go into the take a picture, it shuts off.
Please help.
Mines doing the same thing!!!!!! and this is the second one. the first one, i had to send back DUE TO THE SAME THING. they sent me this one, and its doing the same...THIS CAMERA IS GARBAGE!!!
Posted on May 15, 2008
Please sombodi helpme whit my camera is not power so im tri to fixed so im put the bateryes is not power noting tnks for your help
Posted on May 08, 2008
DSC W80 Error Message - Zoom and Picture Doesn't work
There is something blocking the sensors for the lens position. This can something as small as a piece of sand. The motors and gears that move the lens are very small and delicate. You can send it in for repairs to
Nov 24, 2013 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Kodak easyshare v803 power's on but when lens goes out the power goes off retracking the lens and does not stay on
the coomon caused are lens blocked.
1.- clean the external surface of lens with can air compressed and a soft cloth
2. turn OFF your camera
softly PUSH the lens
3.- Softly PULL the lens while you turn ON the camera
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Cameras
Lens error appaers and cannot take picture
i just fixed the problem. if your error is like mine, than when the lens goes out, hold it so it stays in place. and blow directly on the lense glass thing. than restart the camera and it should work. ok good luck =]
May 19, 2009 | Nikon Coolpix L14 Digital Camera
Hi, all of a sudden, my Canon Rebet XT gave me a faint flashing error 99 message. It won't turn off and the red light at the bottom right of the screen stays on even when I turn my camera off. I have to...
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4.clean all lens contacts on lens and camera with a rubber eraser
5. Insert a fully charged battery, and turn on the camera.
6. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
>from :
May 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera goes to sleep too there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
Put camera on screen come on lens came out thwn power went off now power light wont stay on long enough lens wont go back in
maybe this works: turn your camera on in play mode (if you have play button press it to turn on camera) and if your camera hase a shoot-play switch select play mode and then turn your camera on.) repeat this until lens goes back. I hope this works...
Nov 01, 2008 | Samsung Cameras
Lens won't retract
Knocking the camera sounds like it works but may create another problem. I have had this problem with p-100 , p-200 and now the w50, I have found a small drop, of wd40 placed on both sides ,two opposing sides,of the lens ring where it extends from the body will work also. Don't spray, its a bit too hard to control amount deposited. Use a toothpick or a stick to dip and then drop the oil.
Mar 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Make sure batteries are making good contact
with the battery terminals, and are clean
Nov 15, 2007 | Fuji FinePix E500 Digital Camera
Can't take new pictures!
 Delete some images then try
Still in trouble?
Come back
Oct 16, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
