Question about Kenwood KDW243A Builtin Dishwasher
My kenwood dishwasher kdw12st3a wont stop taking water in and causing it to flood all the time and not work ive had a new inley valve done ans still doing it please help
    Champion:
  • 274 Answers
The float in the tub is stuck move it up and down you may need to replace the float
Posted on Aug 04, 2010
  • 4 more comments
  • arniesnipple Aug 05, 2010
    where is this float is on the side of the dishwasher at the top thanks
  • plante3pups Aug 06, 2010
    its on the bottom of the tub its by the door
  • arniesnipple Aug 07, 2010
    is this inside the dishwasher
  • plante3pups Aug 07, 2010
    Yes.,And drain the tub or dishwasher open up the lower panel check the selenoid,you may want to call a applance person to come and fix the dish washer
  • arniesnipple Aug 09, 2010
    hi ya had a good look i can only find 1 in the bottom that comes up when he has flooded is this the 1 you mean also my dishwasher is coming up with the wrong mine is kdw 1222st3a it not built in its s/steel thanks
    wrong no should say kdw12st3a sorry
I just installed a new drain pump on my dishwasher and now it wont stop running even when the dishwasher is indicating off. Any idea why?
Water on drain tray anti flood is on unplug machine and turn on its side too take water away from flood device and leave for an hour need towels on floor soak excess water good luck
Jun 09, 2018 | Dishwashers
Hi ive lost the instruction manual for the kenwood dishwasher KDW12SL3A could anyone help me please?
You can download one from here:-
www.partmaster.co.uk/.../manuals/Kenwood%20KDW12SL3A.pdf
Feb 01, 2012 | Kenwood KDW12ST3A Built-in Dishwasher
Dishwasher is working fine however at the completion of the cycle and when it sits idle it seems to be flooding from under the filter area.Flooding is slow however but causes headaches when it breaches...
Your water fill valve is slowly leaking water into your dishwasher. Your need to turn off the house water valve, to your dishwasher, and see if the problem stops. If it does then replace the dishwasher water fill valve. If it doesn't stop, then you have water coming in through your drain lines, which is highly unlikely. You will have to check to make sure your drain line has a high loop in it, or install an air gap. Good luck, Appliance Specialists
Mar 13, 2011 | LG 24 in. LD-12BW5 Free-standing...
Hi there, I have a kenwood dishwasher KDW12ST3A an...
For the manual, try this link: http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW12ST3A.pdf
hope that helps
May 19, 2010 | Kenmore 15762 Dishwasher
Kenmore disposal hums, nothing jammed, everything moves freely, but wont spin. reset button stays tripped & wont catch
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Apr 03, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
Error code e4 on kenwood kdw12st3a dishwasher too much inlet wate
HI there,
I have had the same problem as most of you. I seem to have fixed it by
1. Bail out all the water from the inside
2. Remove the filter and 2 x mesh pieces.
3. Continue to bail out the water from the filter well.
4. You will probably find pieces of food or fat/debris in the bottom of the well. Remove these.
5. Tilt back the dishwasher at 45 degrees for 30 mins or so to drain and dry the flood sensor.
6. Boil a kettle and pour it down the well. Immediately put the dish washer on a eco wash (no tablets or anything) with half load (ie half water) and this will ease the water pump.
7. Let the dishwasher run its cycle.
8. Clean the filter again and the filter well.
It sounds quite long winded but with a £250 item you need to take care of it. Make sure you rinse most plates before loading in the future.
Hope this helps!!!
Good Luck!!!
neo
Mar 01, 2009 | Kenmore Dishwashers
Kenwood dishwasher kdw12st3a user guide
GO TO PARTMASTER http://www.partmaster.co.uk/cgi-bin/home.pl
SCROLL DOWN TO BOTTOM LEFT AND USE INSTRUCTION MANUAL DOWNLOAD
AND ITS FREE.
Dec 09, 2008 | Kenmore 15762 Dishwasher
Kenwood dishwasher kdw12st3a error code e3, what does this mean ?
in the manual I have for this machine model E3 means: Longer heating time but not reaching requied temperature. The possible causes: malfunction of temperature sensor or of heating element
Aug 01, 2008 | Dishwashers
I HAVE A KENWOOD KDW12ST3A DISHWASHER AND IT HAS THE E4 ERROR CODE THEY DID NOT GIVE ME A MANUAL WITH IT CAN YOU HELP
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Apr 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Kenwood KDW243A Builtin Dishwasher Logo
218 people viewed this question
Top Kenwood Dishwashers Experts
Oloyede Monsuru
fadirahal
Level 1 Expert
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
