Question about Maytag Dual Cool 25 cu. ft. Side-by-Side Refrigerator MSD2556
Compressor is not coming on. What do I do? - Maytag Dual Cool 25 cu. ft. Side-by-Side Refrigerator MSD2556
  • 725 Answers
You can purchase a hard start relay switch and install it on your compressor. This should bring the unit back up. In the mean time, you should unplug the unit to keep it from burning all the electrical components.
We are a parts supplier and have parts available. Please visit us at:
www.accurate-appliance-service.com.
We hope this helps and we hope you have a terrific evening.
Posted on Aug 03, 2010
Air ride compressor not coming on 1988 lincoln mark vii
It could be your compressor. You can check this by popping it out and putting a 12 volt source on it.
Aug 30, 2014 | Cars & Trucks
I have a 05 Navigator the compressor was not coming on at all. I changed the compressor and it still won't come on.
Check for battery voltage at compressor clutch. Check ECM
(computer) for A/C command. Problem could be in control panel.
Make sure A/C button is on (if equipped)
Sep 27, 2012 | 2003 Lincoln Navigator
My compressor don't come on so obviously nothing
the ptc overload/relay on the side of the compressor is most likely your problem,unplug this part off the compressor and get an exact replacement
Jun 03, 2012 | Maytag Refrigerators
Compressor not coming on check red wire on compressor with test light compressor comes on pressure good high and low air cold
If the compressor came on when you were testing it with a test light, it sounds like something is wrong with your ground for your compressor, and completely the circuit through your test light.
Jul 01, 2011 | 2003 Honda Civic
My friedrich unit compressor wont come on
This could be a bad capacitor or your compressor may have gone bad. Another possibility is an overload that is tripped and has to be reset manually. Hope this helps.
Apr 29, 2010 | Heating & Cooling
Compressor comes on but does not cool below 54
Good day,
The compressor is not starting. Either the compressor has failed, or the starting devices mounted on the side of the compressor are bad.
The parts mounted to the side of the compressor, are the overlaod protector, the starting relay, and on some models a start/run capacitor.
These items can be removed from the compressor, and taken to an appliance parts house for testing. You do not have to go to Sears. If the parts check O.K., then the compressor (a major cost item has failed).
P.S. If this machine is under 5 years of age. leave it alone. Call Sears for service. The compressor is under warranty for 5 years.
Jan 01, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Please help our ac compressor wont come on
Hi, did you change, capacitor for compressor too. check compressor overload switch,(relay) normally located on compressor terminals, (where you connect wires to compressor) that's the device that goes klix when compressor goes to start, could be faulty, or maybe low voltage from your mains(house panel) check line voltage, with digital volt meter, some compressor won't start if voltage drops to low, yes fan will work, could also be, your compressor has a lock rotor, (hard start), you can buy a compressor hard start kit, from appliance store, and try to start compressor, or maybe compressor internal winding, are damage, especially now in summer, when you got a lots of voltage drops, check compressor winding, check compressor winding for short circuit, remove cover on compressor, remove 3 wires from compressor terminal, use ohm meter, put one tester lead on copper tubing that's connected to compressor, and next lead to compressor terminal, one by one, if you get beep (continuity) from anyone of those compressor terminal, you got a short- circuit in compressor, you will have to replace compressor, but if there's no short, them try hard- start kit, replace overload relay, you will see it at compressor terminal location, after you remove cover. good luck.
Aug 10, 2009 | Heating & Cooling
Duro Therm. AC fan comes on but compressor takes 5 min. before
Compressor may have five minute time delay for compressor protection. Russ
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Ac blowing ht air, compressor not coming on
Check the fuses/relay for the compressor. If good, bypass the pressure switch. If the compressor comes on, there is too little internal pressure. Have the system evacuated and recharged. If the compressor does not come on, it could be bad.
May 12, 2009 | 1999 Dodge Grand Caravan
Refrigerators Logo
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
