Question about Siemens WDi1640 Front Load Washer / Dryer
I have a blockage in the fabric softener slot - any idea how to take out the tray?
  • 10,865 Answers
Hello. It is not necessary to take it out. Just pour a quart of near boiling water in in and then run the washer. This will cleanse the entire mechanism. J.
Posted on Aug 03, 2010
The fabric softener drawer is not emptying
Fabric softener is dispensed by syphon. If the softener is not dispensing there might be a blockage in the water inlet. There is usually a twin solenoid the lets water I to the machine. One to the detergent and one to the conditioner. The water path is most likely blocked with water "debris". Try cleaning the tray and housing completely then have another go
Jan 14, 2018 | Washing Machines
My Washing machine hotpoint aquarius WDPG 8640 will not take in fabric softener
It is likely that the tray need removed from the machine and the back side of the drain cleaned. Over time the softener can build up and eventually plug off from the back side. So just cleaning the tray won't clear the problem.
Jun 21, 2016 | Hotpoint Washing Machines
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
I just moved into an apartment and have a Bosch front load washer and dryer. I'm not sure if I'm putting the soap, bleach and fabric softener in the correct trays . There are three slots and I
I am not sure of the dispenser trays but if the clothes are taking to long to dry and are still damp, check the vent hose and the duct work going out the apartment for lint buildup.
Oct 14, 2012 | Bosch Axxis WFL 2060 Front Load Washer
After filling compartments correctly and closing the tray, I see the fabric softener emptying into the washer. Tray does not leak softener when removed and filled.
You are putting too much in there... the tray empties on a siphon priciple... if you fill it too high it will just siphon out...
Use less fabric softener...
heatman101
Dec 13, 2010 | Kenmore Elite HE5t Washer
The fabric softener and bleach trays will no longer feed into the washer they stay full. Any ideas?
Just wondering by taking the top off & cleaning it would this solution be the same if the fabric softener tray has water in it after washing a load of clothes?
Jun 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Why does water remain in the fabric softener tray after a load has finished?
If you are getting good water flow through this section on the final rinse then it can only be a blockage in the tray itself.If you take out the drawer by depressing the button in the centre of the drawer.then wash all the old detergent under the tap.Then remove the small insert in the fabric tray you will see normally 3 raised tubes,these need to be clear and also the part that sits over them,you should clean it thoroughly then refit and try again.
Hope this helps.
Jun 09, 2010 | Electrolux AWF1235 Front Load Washer
Fridgidaire front load will not empty fabric
Hello, W/D here.
There are a couple of reasons why the fabric softener will not dispense. If everything else dispenses properly (detergent and bleach), then I would suspect a bit of plugging. If the softener remains in the dispenser, the water valve above the tray may be sticking. You'll have to get the top up to check it. If there is water in the tray, or some water/softener, then you'll need to look at the overflow cap. Here's how that works: Your dispensing trays for bleach and softener have a raised tube built into them, and each is covered with a loose fitting cap. When water is let into the tray, the level rises under the cap until it overflows, creating a syphon. The softener is literally pulled from the tray, and chased by the water. When the water stops, the tray level continues to drop, until air gets into the cap, breaking the syphon. The cap can be removed and cleaned. Sometimes the tray has to be removed first. Theres a catch towards the rear of the tray.
Best regards, W/D
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Fabric softener always left in tray
hi there are you using concentrated softner if so water is down as some softners are to thick to go through the dispenser also give the whole drawer a soak in hot soapy water incase there are any blockages.
hope this is of some help
Nov 11, 2007 | LG WM-1480FHD Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
297 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
