Question about Bosch 24 in. SMU40 Built-in Dishwasher
SMU50e32SK dishwasher showing E06 in display after a few seconds. Dishwasher has one Main Power PCB and one control unit PCB in the front. Info: Main PSU PCB has been shifted due to overvoltage. All sensor checked, seems to be ok after this has been shifted. I don't think the induction motor(big pump) has been affected due to the relays in front. Could it be the Control PCB in the front or maybe the small drain PUMP. Well some of you properly now what E06 is referring to on this model. BR MEM
  • 11 Answers
SOURCE: Bosch SHU4300 Water Fill Issue.
Similar problem for us turned out to be water accumulating in the tray which set off the float switch.  I vacuumed the water out and function returned to normal.  However, we are now facing a repairman's assertion the clay in our well clogged the water inlet systems necessitating $285 in repair parts and labor.
Posted on Oct 13, 2007
  • 213 Answers
SOURCE: Electronic controls don't count down properly
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Posted on Nov 20, 2007
SOURCE: Bosh dishwasher Class1xx
I think if u take the left side pannel off u will find the meatering tank clogged up which can not fill up the machine at diffrent levels.
Posted on Feb 14, 2008
  • 13433 Answers
SOURCE: I think I need to
Read this page, it may be helpful to you
http://www.repairclinic.com/0088_9_1.asp
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Posted on Aug 03, 2008
BElectric
  • 1140 Answers
SOURCE: I changed my water control valve, thinking my
There is a simple explanation for this - water is leaking into the bottom of your dishwasher under the washing compartment. This has caused the float to rise and trip the switch which activates the Aqua-Stop / anti-flood protection system. This also closes the solenoid (water control valve) which explains why you thought it needed to be replaced.
The only way to check this is to remove the washer from under the counter (disconnect power and water supply first) and tilt it backwards about 15-20 degrees. Water should run on to the floor from under the washer so I suggest putting some old towels down first. Once the water has been drained from under the washer, you can use it again, but it's not advisable if you have a leak. The only way to find the leak is to get access to the bottom of the washer by removing a side panel, usually the right-hand one. As you already replaced the solenoid, you should know how to do this. Once you have access you can run a cycle and try to see where the water is leaking from or you may be able to see signs of corrosion somewhere which should help you to identify the source of the leak.
If there is no water under the washer, you probably have a faulty float switch or possible a faulty control module.
Hope this helps. Post back if you need further assistance.
Regards,
BElectric
Posted on Nov 23, 2010
Error code 6
Good Morning sewblessed - Generally, error code E06 means that when the unit is in the dry cycle, the control does not receive the proper speed feedback from the lower fan. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, then more than likely the lower fan will need replacing and I would recommend connecting with an experienced appliance repair tech to assist further.
Jun 14, 2013 | Electrolux EIDW6305GB 24 in. Built-in...
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Fisher and Paykel DS603 no power
There is a thermo fuse in this unit and it can cause the controller not to power up. It is located on the heater plate, if the unit got too hot this will cause this fuse to blow and cause not power to the controller to a singe drawer unit only, this would not shut down both drawer though. This fuse is not replaceable other than replacing the plate itself. Get back to me if you need part numbers and I can get them for you or you can call Fisher and Pakel directly and they are 24 hours a day service call center. The plate is tricky to replace and you will have to change both seals at the same time, not real pricey though.
I hope this helps, keep the unit, its a good dishwasher.. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 16, 2012 | Fisher DS603W / DS603B / DS603I Dishwasher
I have a Bosch Exxcel free-standing dishwasher that is not powering up. The fuse is okay and there is power at the switch and the PCB. None of the lights in the control switches come on. The dishwasher...
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 16, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher will not run. key pad light sensors are on but it will not run. nothing is obstructing the operation and the door is closing and latching. fine.
could be a few things the touch pad display has a ribbon cable that connects to the pcb or control assemble...the touch pad could be bad /// the pcb(main control) has a fuse in it and they often go bad this reuires taken the cosole apart and removing the screws on the inner door to get it off. if the fuse is not bad you have either a bad pcb or touch pad... before doing all this kill power to unit at breaker for at least thirty seconds and then reset...hope this helps
Jan 02, 2011 | KitchenAid Dishwashers
Had a power failure from bad weather now the dishwasher is dead? checked the fuse box the breaker is fine, there are no lights on the display panel. what is the reset procedure for this dishwasher?
Try turning the breaker for the dishwasher off for 30 seconds and turn it back on. This should reset the dishwasher control board. If it still doesn't work then most likely the power failure burned up the main control board. The control boards in the newer dishwashers are sensitive to any type of power surges or failures.
Hope this gets it running for ya.
Dec 15, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher will not start. Several cycle buttons
check carefully on display buttons 2 buttons are marked reset push these together as you turn mchine on this should clear error if not you may have control pcb fault will need service tech.
May 26, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
LG LDF6920ST Dishwasher won't start
With nothing displaying and only the humming sound, it appears that the main controller card (PCB) has most likely failed.
If it were my dishwasher, I would add a pitcher of water (more than two big glasses full), close the door and start a cycle and listen at the drain. The first thing a dishwasher does is run the pump to empty any standing water before it fills up. If you hear that water drain, (and can see that is has drained from inside the dishwasher) it is not as broken as I think it is.
BUT, this dishwasher should be displaying something from the moment you press the power button.
Please post back with what you find and decide you do. OK?
Apr 17, 2009 | LG LDF6920ST Stainless Steel 24 in....
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Dishwasher isn't turning on
Hi
Kindly turn  it off for 10mins and then after restarting press the stop button twice.
Feb 19, 2009 | Dishwashers
Dishwashers Logo
77 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
