My wireless adapter seems to only work sometimes. The physical switch is switched to on but it still says that my wireless is disabled
    President:
  • 2,571 Answers
Try to enable through network connections.
I have a compaq laptop that was like yours, now it has stopped working, i have to use a usb dongle.
Google your model number to see if its a common problem for you laptop.
Your adapter can be found here
Control Panel\Network and Internet\Network Connections
right click on the adapter and enable
Posted on Aug 03, 2010
My 802.11 WAN adapter seems to have "disappeared"
Here is a link to IBM's website for trouble shooting the wireless adapter
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-50402
From the above link:
Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
I hope this helps.
Best of luck!!
Mar 03, 2011 | Lenovo ThinkPad R61e Notebook
Lap top will not conect to the wireless internet connection
If you are on a laptop: (windows)
1. check to make sure your physical on off switch for the wireless card is turned on. Windows will sometimes still show it as being active while the switch is physically still off.
2. Disable/re inable the software connection to the wi fi
(MAC) Disable reinable the wireless card in dropdown menu
3. restart the wi fi router
Jan 16, 2011 | WiFlyer - Portable, shareable WiFi base...
Internal wireless modem on but os does not recongnize it
check the network adapters in control panel, right click on the wireless adapter, check to see if it was inadvertently set to "disabled" then there is also sometimes a wireless off/on soft switch like FN button and a corresponding number key (look for the wireless icon), and sometimes a wireless physical switch on the front or side. if the above all fails. Identify the adapter. I would flip it over to get at the bottom, next I'd take the bottom cover off to expose the wireless adapter, this cover is typically marked with an antenna icon on the bottom. the card fits into a small slot about 1 inch wide held in by two clips on the outside. very easy to get out. then look at all the markings to identify what wireless make/model the card it is. and you can also check to make sure its not gotten knocked out of its seat. Now you know what your dealing with you can surf to the manufacturers website and look for a "driver" or software for your operating system. eg. vista. or xp. download, install , reboot. and with an ounce of luck. it will now work. (alot of these adapters also install ) best of luck. Cheers
Aug 25, 2010 | Panasonic Toughbook CF-27 Notebook
Wireless radio on Lenovo Y510 turned off even though the slider switch is switched on and lights up. How can I turn on wireless radio?
Hi There and Welcome to Fixya!
Another way to turn on the wireless radio on your Lenovo Y510 is to press and hold the "Fn" key, then simultaneously press the "F5" key.
This is an alternative way to switch the wireless antenna on or off without using the physical WIFI switch.
Hope this helps,
Thank you for using FixYa.
Aug 21, 2010 | Lenovo IdeaPad Y510 Notebook
Reinstalling the wireless adapter
vista have this problem...
first, switch off computer and remove physically card from the computer, then de-install all possible traces of it, run ccleaner and clean the computer as well as registry.
go to d-link site and download newest drivers for your adapter, and os (vista). unfold software to c:/dlink
switch off computer again, re-install card and re-power the computer.
when automatic software install start, select manual install, point to newly created folder c:/dlink and select appriopriate driver from there, install.
this procedure usually solves the problem, vista try to instal generic windows drivers not specific hardware drivers, to prevent occurence of that, disable automatic updates in vista, and once a month or so, do only and only security updates from windows, never, ever update your hardware drivers from windows as these are just generic drivers generating more problems than solving. hope this help.
Jul 26, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
How can I turn on the wireless capability on my Asus G60VX laptop? the switch on the front left is on and still nothing. trouble shooting says wireless capability is turned off. it was working fine untill...
I can figure out that your laptop runs Windows Vista. Go to Control panel, then Network and Sharing centre and then go to Manage Network Connections and see if the Wireless Network Connections icon is disabled, make sure it is enabled and not connected. Try disabling and enabling it again. If still no go, try to manually turn off the wireless switch and turn it back ON. Check the light status (if any), confirm the error message too. If still, it seems not to be working, then the internal switching might have gone bad. You need to get the laptop serviced.
Regards,
Arvind
May 25, 2010 | ASUS Operating Frequency 2.4 - 2.5 GHz...
Toshiba satellite wifi not working
Hello
You might have physically switched on the adapter, but in Windows it is still disabled.
In Windows XP, click the start button, look for CONNECT TO (don't go in the all programs menu), and click SHOW all connections. A window opens showing all the connections available. If the wireless connection icon displays a red X crossing it, it is disabled.
To reenable it,
Point the mouse cursor to the wireless connection and right click mouse button. Click enable or repair.
One question though. If your computer is toshiba, you must have installed the configFree software that came with it.
If so, look to the left right of the task bar and click the ConfigFree Icon. Choose Connectivity doctor. It will diagnose your connections. If one is disabled or has a problem, a yellow triangle with an exclamation mark ! will appear on the connection.
Use the device setting thumbnail, select your WIFI adapter . A button at the right bottom side, will show either Enable (if your adapter is disabled), or disable i(f adapter is enabled). With that button, you can toggle between enable and disable. After that click the close button, and hopefully you will be able to surf the web.
Hope it helps
Hope it helps
Aug 21, 2009 | Dell Inspiron 6400 Notebook
All of a suden says No Wireless Adapter. It is built in(confused)
I have a DV6275
There is a switch in the front left corner.
Be sure that there is no red light ... it says "wireless" move it to the right and it should turn BLUE.
This is the likely reason it fails to work.
Sagaciuos1
Aug 07, 2009 | HP Pavilion dv6000z Notebook
My Dell Inspiron E1505's wireless switch is off.
This happened to me using a Dell Inspiron laptop. The wireless switch was disabled and the answer was supposed to use both the blue Fn and regular F2 function key to enable wireless connection. I tried Fn and F2 together and it did not work. I tried just F2 alone and it worked.
Jul 25, 2009 | Dell Inspiron E1505 Notebook
HP Pavilion dv4000 computer, wireless button disabled
Go to the control panel, hardware, device manager. Uninstall the wireless adapter then restart the laptop.
You can also download the HP wireless assistant:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-33346-1&cc=us&lc=en&dlc=en&product=468789
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 30, 2008 | Computers & Internet
Computers & Internet Logo
1,878 people viewed this question
Alun Cox
David Payne
David Payne
