Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio stop during wash cycle. Displayed flashing "LD" tried powering off, including unplugging .... tried drain/spin but it just makes a humming sound, water does not drain...nothing happens. suggestions?
  • jyonkin Aug 05, 2010
    CHECKED, PUMP, DRAIN HOSE. ALSO OPENED LID, REMOVED TUB AND CLEANED DRAIN. WASHER BEGIN CYCLE BUT DOES NOT DRAIN....HUMMS A BIT THEN STOPS.
    J YONKIN
  • 6,784 Answers
HI. This will be a long drain code(LD). Ld flashes when the water level does not change after the drain pump is on. Follow this testing procedure to solve the issue.
Cabrio test for LD code:
Perform the following checks if washer fails to drain or recirculate.
1.
Perform the Manual Pumps test. This procedure can be found in the manual i have provided below.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom of the machine and the pumps. See Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Click here to access the service manual that will correlate with the instructions given above in the testing procedure. This manual is very large, so allow 3 to 4 minutes for the entire manual to download to your hard drive. If the download procedure is interrupted, simply, refresh and allow it to download, once more.
Posted on Aug 05, 2010
  • 1 more comment
  • Michael Masters
    Michael Masters Aug 05, 2010
    • Component access procedures like removing the console will star on page 4-1 in the manual provided.
  • Michael Masters
    • The drain pump component testing procedure will began on page 5-2
  • Michael Masters
    • Diagnostic and manual testing will began on page 6-4
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 03, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Cabrio. Why does it stop during rinse cycle?
Possibly the pump has something clogging it and it takes too long for the water to drain out therefore causing the internal time to take too long. Remove pump and see if its clogged.
Jul 26, 2015 | Whirlpool Washing Machines
My whirlpool front loader cabrio stopped working with 12 minutes left in the cycle. The Ld code is flashing and I don't know how to fix it so that the load will spin and drain. How do I fix this...
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid lock will not lock
You can check for the correct part before ordering it on the reliable site :
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts?s=b6a11c212
Thank You for contacting Fixya and please accept the solution if it has helped you.
Jun 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LD appears. I cannot shut off unless I unplug it
Long Drain you may have a something in the drain hose or drain pump or damaged drain pump.
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.  Press STOP/CANCEL to clear the display.
Sep 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
We have a Kenmore Oasis HE.It stopped during the rinse cycle
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
