Question about Lexmark Z640 InkJet Printer
How do i put the ink in to the printer can you show me a pic of where it goes
    President:
  • 2,571 Answers
Pixma mg3150 ink there but showing as empty
When using replacement or refill, Canon software will not detect them as new or filled with ink. Original cartridges have chips programmed with "counters" which determines how many times it could print. As long as it is printing, it is not really a problem just press the resume button.
Apr 25, 2014 | Canon PIXMA MP150 All-In-One InkJet...
I have a HP OFFICEJET 6000 WIRELESS PRINTER AND I JUST PUT A NEW BLACK CARTRIDGE IN LIKE A MONTH AGO AND YESTERDAY I PUT IN BRAND NEW "MAGENTA,BLUE AND YELLOW IN I PRINTED ONE PAPER PERFECT ALL THE...
Check ink levels, if showing full go to the printer properties, printing preferrencess,servicess, nozzle clean,..after cleaning the nozzles check print quality..
Sep 08, 2011 | HP LaserJet 4700 Printer
I have never used the Photo ink Cartridge #58. It intal pic shows putting it where the black one goes-does this mean I would use the color and the photo one at the same time instead of the black one?
Yes correct.The photo cartridge has to be inserted, where you install black cartridge.The photo cartridge gives finishing touch to the photos which you print.The actual photo comes from the color cartridge only, but for lightness and darkness, the color(ink) from photo cartridge gets used.In photo cartridge there are three color ink, that are light pink, light blue and grayish black.In color cartridge there are three color ink, that are pink(magenta), yellow and cyan( blue).------------- This are the details.Thank you for using fixya.
Mar 24, 2011 | HP Deskjet F340 All-In-One Printer
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
New Ink does not show up on Paper!
Did you remove the plastic film off the cartridge before you put it into the printer?
Apr 20, 2010 | Dell A960 All-In-One InkJet Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Pic`s wrong colors
you need to check
1) same color ink of the cartridge almost empty, change a new ink cartridge or refill the color ink (there is only one ink cartridge)
2) the cartridge ink channel dryer and constipated, take out the cartridge put the bottom surface touch down clean water (a little) 1 hr, then set back if the cartridge has enough ink.
Feb 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot print off scanner file- can print from database files
I want to print data but printer shown error 5100 and show message printer off line of see manual guide
Nov 19, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Black dots of ink all over my pics.
On most inkjet printers there is a small squeejee which wipes of excess ink from the printer head, this is usually done where the printer head parks itself while it is standing by.
I am 99% the below steps are safe as I have done it to my printer dozens of times.
while the printer is off, pull the head across so that you can see the condition of the parking position. look with a torch to see if there is ink splattered everywhere.
if there is ink everywhere use pure alchol with long cotton buds and clean
let me know how is goes
Jul 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
My black ink in my PIXMA MP760 printer will not print. I have gone throuh the maintenance process for cleaning and deep cleaning the heads and it still will not print any black whether it is text or...
The print Head has gone bad. Not using a printer that often will dry out the print head. The print head is where the ink goes. Try to get a cue tip and put some Alcohol in the place where the ink goes through. These should be small sponge like things underneath the ink cartridges.
Jun 06, 2008 | Office Equipment & Supplies
Lexmark Z640 InkJet Printer Logo
104 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
