Question about Garmin Nuvi 660 GPS Receiver
Full charge lasts just under 3 hours
I charge the nuvi 660 and in less than three hours the screen goes black. It is only a couple weeks old. What is the problem? Should I return it or contact garmin for a repair?
Thanks.
  • 3 Answers
The battery life is advertised as THREE to 7 hours. Try reducing the backlight time. You're within factory specifications.
Posted on May 02, 2008
How long does it take to charge a new garmin660?
If the battery is in good condition, just a couple hours. Plug the charger into the unit and you should see a yellow lightning bolt over the battery status indicator. 4 green bars means the battery is charged. Anything less and it is not.
To leave the unit in charge, press the on/off power button until the screen says battery charging. You can check the charging status by just touching the screen. If it says battery charge complete, then you are done.
More info here:
http://www.sharc.net/gps_charger_repair.htm
http://www.sharc.net/gps_battery_repair.htm
- Jim
Aug 26, 2011 | Garmin Nuvi 660 GPS Receiver
Unit shuts down after about one minute.
When you leave a Nuvi on a charger for several hours and don't see full green bars, this is an indication that the battery is defective. Most Nuvi batteries last about 2 years. Most of the batteries have a date code of 2007. I would have the battery replaced as soon as possible as it can bloat and crack the case open. More info can be found here:
- Jim
Jun 01, 2010 | Garmin Nuvi 660 GPS Receiver
My nuvi 660 sound keeps cutting out, when i tap it it comes back for a few seconds seems like a connection is loose
if you mean the screen just goes blank but the gps is not turning off, go to the tools section (little wrench icon) then system then make sure safe mode is off.
if your 660 is powering off totally, make sure it is fully charged by charging it via the usb cable to your computer for a few hours.
bill
Nov 07, 2009 | Garmin Nuvi 660 GPS Receiver
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Screen shuts off within 10 seconds after turnon, if power not connected to car
replaced battery. works fine now. holds charge for some six hours or more.
Oct 07, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660
my nuvi was working great til last week when for some reason it would not load maps, get stuck on the first screen and then just shut down.
Jan 22, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
Getting started with new Garmin nuvi660
Plug your 660 with usb into the usb port, computer must not set on sleeping mode (screensaver).
It will take 3-4 hours to be full charge
Dec 18, 2007 | Garmin Nuvi 660 GPS Receiver
When you are charging the Garmin Nuvi 660 how do you know when its done charging?
No way to know except you disconnect and watch your 4 baterry bars.
It take almost 4 hours to be full charge.
Dec 10, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 forget my pin
The only options you have when it comes to a locked unit is to enter the correct PIN, go to the location where the PIN was set, or send the unit back to Garmin. There is no way to unlock a PIN locked unit without the correct PIN or location.
Jul 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
65 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
