Question about Sanyo DP42746 42 in. Plasma Television
Sanyo Vizon 42" Plasma DP42746 Was using tv when I heard a click and I lost all audio and video, could not change the channel or adjust volume. Tried unplugging and sitting for 10 minutes. Plugged back in, I sometimes hear the click on hitting power, light comes on then it clicks again. Powerlight stays on, no audio or video. Sometimes I hear no click but power light stays on, no audio or video.
  • 6 Answers
This is a common problem with these TVs. You can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. I uploaded it here when I had the same issue with my TV last year. The solution is almost always to replace the Power Board (Y-Main) and the Upper and Lower Y Buffers. The parts and costs (from Sanyo in July 2009) are listed below (NOTE: Sanyo will not ship these parts to anyone but a repair shop): 1. V4 Y-Main (Y-Sustain) Circuit Board (Part # LJ92-01200A, Alt Part # LJ41-02759A) - USD $139.00
2. Upper Y-Buffer Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3. Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD $64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for parts to USD $277.50. From my research, a shop would probably charge between USD $500 and $700 to do this repair. FYI - there is a class action lawsuit pending against Sanyo for this issue. The V4 Y-Main (Y-Sustain) Circuit Boards fail VERY frequently in this TV due to overheating. Hope this helps.
Posted on Aug 07, 2010
  • 2 more comments
  • Steve
    Steve Jan 04, 2011
    I took this advice and switched out my Y main board and my Buffer board for my Sanyo. After replacing the 2 boards, the tv comes on with static, and no sound. Is there a factory reset to get the tv working with the correct parts? It was a blank screen with "No input" on it (how it should be) for about 3 seconds before it cut back out. Please help!
  • EBC ELECTRONICS Jan 05, 2011
    The best way is to replace all 3 boards at the same time. You replaced just one y-buffer board, probably second one still had a problem and now y-main is bad again.
  • Steve
    Steve Jan 06, 2011
    When I was on the phone with a Sanyo customer service rep, I provided my tv serial number (not just the model number, she said models can vary) and was informed my TV only has One Y-buffer board, cost $120. Even the TV repair shop said I only had to replace the Y-main and the Y-buffer.
  • Steve
    Steve Jan 06, 2011
    Y-Buffer Part # LJ92-01344A AKA 996500036819
  • 163 Answers
EBC electronics has a repair service for set of these 3 boards.
Posted on Oct 14, 2010
    President:
  • Sanyo Master
  • 1,779 Answers
It sounds like your Y Sustain panel has gone out. Locating the part and the price might put you at the 50% category in which a new set at that point would be in order..
Posted on Aug 03, 2010
3 Suggested Answers
  • 1738 Answers
SOURCE: 42' plasma won't show picture or sound.
It is your man power supply board.
Posted on Dec 09, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
Posted on Apr 17, 2010
Is it possible to connect hdmi cable to sanyo vizon plasma tv
yes it is possible there is one HDMI input on the back of the television
Dec 11, 2010 | Sanyo DP42746 42 in. Plasma Television
Sanyo model #dp42746
Change your channel till it reads D 03-01 then use scan feature.
Mar 27, 2010 | Sanyo DP42746 42 in. Plasma Television
No video but audio is fine on Sanyo 42" DP42746 TV
If you unplugged the Ysus board, then you need to replace the Ysus board, or both sustain boards. This is the part: The part is often available on Ebay, or from manufacturer. Look also at Vance baldwin or Partstore. To do a good job the Sustain boards should be tested by a tech , following service manual. It is almost for sure sustain board by the way.
Oct 12, 2009 | Sanyo DP42746 42 in. Plasma Television
Finding AV channel to connect DVD to TV
first check if you are plugged in the right place,(you're tv as 2 a/v inputs).then you should be able to acces a/v by the menu button on you're remote,or even on the t.v. itself.well good luck then buddy,hope this helps.. btw,are you plugged in a/v (yellow,white,red) style,s-video(1cable)style,componentstyle(green,blue,red).check that out man!
Nov 16, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
2,292 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
