Question about Toshiba REGZA 42RV530U 42 in. LCD HDTV
The power shut off after lightning striked and my toshiba 42rv530u tv's display is grainy with grey vertical lines in all display modes when the power came back on. also, what i thought was a surge protector, was really just a multi-outlet cord. what can i do to fix this? the warranty has expired and i can probly replace the part myself if someone can tell me what exactly has fried.
    President:
  • 1,099 Answers
All plasma an lcd tvs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 03, 2010
Which circuit board on my Smart TV might be broken after a possible lightning strike. There are two main ones. The power is getting to the unit, but I can't get the menus, connections etc to work.
Nobody can predict, what might have been happened to your TV after a lightning strike. Do you thing anybody can? Is any technician have a super-natural power to predict the faults that might have been happened due to lightning (More than 10 Million volts to start on stroke) ? Can you?
Sorry.
Contact the authorized service center. OK?
Jul 29, 2015 | Toshiba Cinema 47L7200U 47" 3D 1080p...
Will a nearby lightning strike cause a power board failure?
It could happen yes it would depend where the strike entered the TV. Not all lighting strikes hit on the electrical lines, on a TV they can come through the cable, as well as a antenna if you have one hooked up.
May 10, 2014 | Samsung UN32EH4003F
Lightning strike, blows internal fuse (6.3v 125/250) on plug in.
sounds like the lightning strike took out at least the power supply if not more. sorry to be bearer of bad news.
Oct 31, 2010 | Toshiba 24AF41 24" TV
42rv530u toshiba tv no sound no picture change power supply and main board
The 42RV530U is known to develop problems in both the power board and the main board. You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
Aug 12, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Thin black verticle lines on screen some disappear when warm toshiba wide screen tv
The post is a bit confusing. However, I have a Toshiba 42rv530u model where vertical lines appeared. Tech came out and ordered a new panel. It sounds like the same situation with you.
Nov 09, 2009 | Emerson Televison & Video
No pic and no sound on toshiba regza was told the power board was out is this an expensive fix
Hope this helps.
Nov 04, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Need to remove tv stand
There are 4 screws you need to remove to get the stand off.
There is 2 vertical screws near the ANT/CABLE port and 2 more vertical screws near the power cord.
The stand should slide out after that.
May 17, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Lightning Strike?
Assuming this line is across the screen horizontally (side to side), this means the vertical deflection circuitry is dead. In late model sets, there is a Integrated circuit package which drives the vertical yoke coils. Possible defects: the I.C. itself, bad solder connections where it solders to the board, missing voltage source to this I.C. (often around +24 volts), or a bad electrolytic capacitor in the associated circuitry. This latter often results in a non-linear picture, or less than full deflection condition, rather than a thin line only. It is possible lightning caused this problem, (I've seen some rather illogical damage from lightning ) perhaps it produced enough of a surge to pop the I.C. or a fusible resistor in that voltage source noted above.
Jul 03, 2007 | GE 24GP653 24" TV
Possible lightening strike
Lightning will create a lot more damage,the vertical circuit has become defective,the repair should not be expensive better be safe and call a qualified technician.
Sep 18, 2006 | Sampo SME-27FDL5 27" TV
Toshiba REGZA 42RV530U 42 in. LCD HDTV Logo
160 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
