Question about BenQ T905 19" LCD Monitor
Hey i got BenQ T905 19" LCD Monitor, problem is the monitor menu keeps popping up every few seconds and selects the firs menu then continues its like someone keeps pressing the menu button then Ok and Ok and Ok, and forever any ideas pls ? its really frustrating that in the middle of something to have a blue box in the middle, and sometimes even pressing the exit button wont close it until it goes through the menu
  • 5 Answers
SOURCE: BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Posted on Jul 19, 2008
SOURCE: BenQ FP731 17" LCD Monitor Problem
Had the compete dark screen problem. Green/amber power light was coming on and off as expected but no image would appear on the screen.
Found PF751 to be open.
Thnaks for the help people.
Posted on Oct 08, 2008
dragon_sun25
  • 107 Answers
SOURCE: benq t905 monitor blank
Fist check the fuse on the inverter board if it is blown replace it if not you need another inverter board as it has fried. But I looked and was unable to find a new/replacement inverter online so I wish you the best of luck
Posted on Dec 08, 2008
budmrtn
  • 11361 Answers
SOURCE: Benq T905 Monitor's green light turns on and then
Check for blown MOSFET IRFU9024N and transistors C5707/5706, and fuse in the inverter circuits section. Also look for bad caps with bulging top/seal. See some pictures of failed Dell monitors (BenQ made alot of monitors for Dell), http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 14, 2010
SOURCE: benq computer monitor shuts down after standby in energy saving..
There are 6 (reduced quality) capacitors in the BenQ Q9W5 which cause the screen over time to 'fail to sync' when turning on or resuming from standby.
They are;
4x 470uF 35v, and
2x 1000uF 16v.
I recommend the following replacements if you are in Australia (the ones I purchased from Jaycar only lasted 12 months);
(470uF) http://www.altronics.com.au/index.asp?area=item&id=R4865
(1000uF) http://www.altronics.com.au/index.asp?area=item&id=R5182
Posted on Aug 05, 2010
My monitor is eperiencing OSD locked and it keeps on popping out the screen. how do i fix it?
Hi rimandopaolo,
I see that you are getting the OSD locked pop up on your screen.
Press the Menu button on your LCD monitor look for the OSD option on the menu once pressed selct the OSD option try to see if it will give you an option to unlock the OSD setting on your LCD monitor
I hope this helps.
Have a nice day,
mvincentc
May 11, 2011 | Hannspree HW191D LCD Monitor
Benq T52WA LCD MONITOR SMPS OUTPUT VOLTAGES?
Hi
My Benq t52wa wide screen monitor works fine for some time and then its goes off for a few seconds and then comes back in regular intervels. This keeps on happening. Also im unable to get the auto adjusting thing that comes on the screen to go off. IT keeps adjusting.
I checked for the drivers and it says all drivers are up to date. Any suggestions please?
Feb 13, 2011 | BenQ FP553 (White) 15" LCD Monitor
Auto Adjust keeps popping up
Is this a computer moniter or a tuner/tv
Aug 02, 2009 | BenQ FP71G 17" LCD Monitor
I keep getting a little blue screen pop up that asks me to select input, d-sub or dvi. I select either then hit enter on my monitor but it keeps popping up. Any ideas how i can fix this.
you probably got a loose connection inside you monitor or your cable is loose, check both ends
1. check the end that goes to the video card
2. chec kthe end that goes into the monitor
3. if that does not shore it up it maybe a short inside so you may want to check that.
thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 16, 2009 | BenQ T904 19" LCD Monitor
Monitor Menu
HI,
Looks as if there's a problem with the menu button and it needs to be replaced.
Jun 24, 2009 | HP f2105 21" LCD Monitor
Benq FP222W
Your monitor must have multiple inputs (Dvi,D-sub) so it searches when you start for which input is connected.
If menu popping up intemittently is your problem,The culprit is generally defective (Leaky) Key switches.You need to pen up monitor and replace.
Normally BenQ has a 3 year warranty.
Dec 28, 2008 | Computers & Internet
LCD Main MEnu
hi,
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Keep me posted.
Thanks
Dec 03, 2008 | Dell E173FP 17" LCD Monitor
Benq fp91g+ monitor doesnt stay on
Hey...Superb****,
It's seems your monitor it *******...Hehehe... Due to busted backlight inverter.
Need to replaced a new one or repaired it.
Jul 09, 2008 | BenQ FP91G+ 19" LCD Monitor
Benq Fp737s
Hello Guys!
The problems you face may relate to the key switch panel,one or more of the key seems to be leaky.Clean all switches with switch cleaning fluid like WD40 or most reliable solution is replacing all these switches.
Please rate this solution.
Samir
Apr 09, 2008 | BenQ FP737S-D 17" LCD Monitor
Problem on hp monitor
I know you said there were others that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Oct 12, 2007 | HP Pavilion F1523 15" LCD Monitor
BenQ T905 19" LCD Monitor Logo
135 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
