Question about Sharp AR-M455N Copier
We are trying to connect our boss' CPU to this copier so he can print right to the copier. How do we do this? How do we get the IP address for this copier?
  • 748 Answers
Does anyone else print to this machine? If so, go to the printer settings on that computer, choose "ports" tab and see to which IP address it's directed.
Posted on Aug 03, 2010
Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | HP LaserJet 1022n Printer
When networking, I can see the printer on the network, but when I send a test page, the printer immediately says "cancelling". I cannot figure what the problem is. Any suggestions?
There must be IP address conflict.
Check the Dell printer IP address
Open Printers and Faxes Folder
Right click on printer icon ( dell )
Click on Properties
Under Ports Tab check the IP address with check mark
If the Ports IP address is Different as that in Dell Printer
Highlight the Port with IP address and click on Configure IP below
Change the IP address to the Printer and Click OK
Also check if there are print job stuck in the Queue ( like no. 1,2 )
The printer icon should show READY and 0
Or Else, Right click on the printer icon and Click Cancel Print job.
Restart your PC and Printer and try to print. It should work
If this does not work, let me know what is the Operating system of your PC
Try this Step if your Operating system is Windows 7
Left click on Troubleshoot
Continue with the Wizard and complete it
You are ready to print.
Nov 02, 2010 | Dell 3000cn Laser Printer
Hi, we cannot print to the Ricoh Aficio 2022. I have connected to the printer by pinging the IP address of it and it is OK. The 2022 can still photocopy. I have tried a test page and nothing prints.
Are you sure no other device on your network has the same IP address? (Turn the copier off and trying pinging that IP address to make sure.)
Do you have the Ricoh 2022 driver installed? You can download it from Ricoh-USA.com if you don't have it.
Aug 23, 2010 | Ricoh Aficio 2022 Black and White Copier
Print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Nov 07, 2009 | HP Color LaserJet 2600n Printer
I want to print copies from my workstation how to i connect this to canon ir3300
For that it should have a network adaptor, if that is availabe just feed an ip-address in machines, and connect with your workstation and installed the driver of printer.
Jul 09, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Networked Canon imageRunner 2800 printer stopped printing right
Your modem was almost certainly your router and contained a static IP address for your copier. Check what IP address your copier used to use. In the Printer Properties/Preferences can't remember which there should be a TCP/IP port. What is the IP address for this?
Go into the copier, go to Additional Functions > System Settings > Network Settings > TCP/IP settings > IP address. Turn DHCP off (make sure DHCP box is filled with white). Enter IP address. Press Ok/Enter (if there is a button that says so, can't remember at the moment)
Turn copier off using main power switch on right hand side of copier then back on again.
Does it work? If yes, good.
No, check the IP address of your new modem/router e.g. 192.168.0.1. Is the IP address of the copier in the same range, that is are the first three out of four numbers the same (last number must be different)? If not, change the copier's IP address so that the first three numbers are the same. Make sure the copier uses the same Subnet Mask as the router/modem e.g. 255.255.255.0. For the subnet mask all four numbers must be the same.
May 30, 2009 | Mtd 22" Yard Machine Push Mower
Can't rip to 3200
There are many reasons this could be occurring, first I would try pinging the copier to make sure you have connectivity
Go to run command type cmd then in command prompt type
ping xxx.xxx.xxx.xxx replace x's with copier IP address.
If you get 4 replys then the copier is online and responding most likely the IP address in the print driver is wrong and needs to be changed.
Ck IP address of print driver by right clicking printer go to properties the select ports tab. Find port and check address if it si incorrect then change to correct and hopefully it will correct your issue.
I can give more help if this does not correct your issue.
TankMurdock
Apr 27, 2009 | Canon imageRUNNER C3200 Copier
HP C6180 Print Queue Error
click start, click on network, when you see the printer on the network, right click the printer and copy the IP address shown there.
click start, click on printers, right click the printer, click on properties, past the ip address into the location bar, then clikc on ports and make sure the correct IP address is check marked, if not add the corrent one using the add port button,
Apr 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printing only test page
when you click on the print in Microsoft Word is the printer there, is it set as the default printer?
Try this:
 click on File
Print
right click on the printer
go to Properties
Set as default printer
Oct 25, 2007 | HP LaserJet 4 plus Printer
Sharp AR-M455N Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
