Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
My 4100 bell receiver doesnt get solid green light looks like getting signal
One senser is green one is amber
Make shure that the green and amber lights on the sensors are solid and not flickering ! most of the time when a sensor is not aimed exactly at the other sensor it will give a weak signal and not allow the door to come down , we call this a constant hold down since you have to physically stand and hold the wall button down for the door to go down , Your sensors are made up of a receiver and a sender , The sender always will be lit but the receiver may not receive a strong signal since it,s beam may not be pointing at the sender ...check to see if that's the case, also look for cob webs around the sensors since that can also trigger this , another thing that people always do is put brooms and shovels near the sensors and wind up getting a bad signal because a shovel is in the way of the beam , Check these things and you should have success in fixing your problem ! Hope this helps Sincerely Glenn
May 19, 2014 | liftmaster Garage Door 1/2 Hp
When i turn on my dash lights my right turn signal stays solid green and doesnt blink
Hello Kellie.
Usually when this happens a filament in a bulb has broken and crossed over to the signal light circuit feeding it from the park light circuit.
Check the bulbs in the rear right and front right.
You might as well replace all while you have them out, they are not expensive.
They take a #1157 bulb.
If you need more assistance with this ask me here.
Thank you for using FixYa.
KL
Jan 29, 2011 | 1988 GMC C1500
When i hook up my Bell 4100 Sat receiver to the Aux 1 in, i receive the sound but no video. I have tried using all sorts of combos, s-video and yellow video cable. The tv is hooked up witrh HDMI from the...
Thanks for clarifying that for me. The simple answer is the Denon home theater isn't able to convert the signal from your Bell receiver into an HDMI compatible format. You'll need to use either S-Video or the regular yellow cable to connect your Home theater to the television. The HDMI out provided would only work for the internal DVD player. This is a limitation of HDMI, not a problem with your home theater. You need HDMI in (or DVI in) to get HDMI out.
May 02, 2010 | Denon S-301
I have a Linksys modem with a netgear wireless router. The other night my internet just stopped working and now it is though the modem is not transmitting a signal. I have connected 2 different computers...
the ds light is for downstream which is your digital signal simply put...... if the light is not going solid to denote being :"online" there maybe signal related issues. rain will mess up the cable signals as the service is exposed to elements etc.....here is a trick i do with a modem that doesnt want to lock on to good signal.....reboot the damn thing...........give it a minute or two.. if the online light doesnt sync up solid....unscrew the cable connector on the back of the modem while it is powered up and wait 15 seconds////then screw it back on (needs to be hand tight, its like a water hose, if its loose you get signal loss) and give it 10 minutes......if it still doesnt lock up and go solid indicating online then call your cable company, you should not get charged for their service not working correctly..........it then would be something only a tech could fix. but if it does lock up and go solid ....hook up your router , power it up and give it a minute to sense the modem, restart the computer and you should be good to go...
Jan 21, 2010 | Linksys WCG200 Wireless Cable Modem 54G...
There are two indicators on gtm20 car charger. what are these for: power and fm signal?
Yes, you can download the manual here:
http://www8.garmin.com/manuals/GTM20-FMTMCTrafficReceiver_OwnersManual.pdf
The 1st indicator is power (green)
2nd indicator:
Yellow flashing : determining what country you are in.
Solid Yellow: seraching for signal.
Solid Red: loss of sync.
Solid Green: Normal traffic data.
- Jim
Dec 29, 2009 | Garmin Nuvi 660 GPS Receiver
I have the solid green light but neither my wife or daughter are able to get a wire-less signal on their Macbooks. A direct ethernet connnection works.
Hi gknue,
There are a couple of things that could be wrong here. It could be that the router that you are receiving your wireless signal from is having problems. If that's the case then simply turning it off for 30 - 60 secs and turning it back on may solve the problem.
If the connection is encrypted, you need to find out what the WEP or WAP key is and then connect via the settings in your Macbooks.
I'm assuming that when you say "I have the solid green light" you mean that your wireless connection is working just for you. If this is true, then look at your network settings and compare them to your wife/daughter's Macbook.
Hope I was able to help.
Sep 16, 2009 | Apple AirPort Extreme Router
4100 flashing ethernet light
If the internet light is not on that indicates a prob with your ISP, call them up and arrange a service call. I had a similar prob a few weeks ago and they had to replace the drop to the house from the telephone pole.
Sep 02, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Problem with vivitar vivacam 4100
the problam is most likely the video card in the camra.take it back to the store you bought it from and have them take a look at it.
Feb 05, 2008 | Vivitar ViviCam 4100 Digital Camera
Speedstream 4100 modem
can be a deffective modem.. they Bell.ca had replaced mine only 5 times..
Dec 29, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens Speed Stream 4100 modem - worked last week - now no lights
This modem is for AT&T broadband only and requires AT&T software to function.
Jan 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
112 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
