Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer in side by side built in refrigerator is not cold
    President:
  • 2,702 Answers
First have the thermostat checked if its faulty it will stop the freezer working there could also be a compresor fault there?
Posted on Aug 03, 2010
  • lmwienshienk Aug 03, 2010
    GE replaced computer board yesterday. Freezer is up to 36 degrees and holding.
Maytag MSD2651HEW refrigerator not cool, freezer works fine. If open both doors, feel cold air blowing in refrigerator side
try keeping the freezer door shut while felling for cold air blowing over to refrigerator side..if so problem lies in the thermostat...its not sensing the correct temp for the fridge side and closing the damper too early...also check to see if there is frost built up on the back wall of the freezer section if thats the case then you are at the begining stages of a defrost issue and soon no cold air will blow over to fridge side..let me know what you find
Mar 13, 2012 | Maytag MZD2766GES Side by Side...
My Maytag Plus refrigerator does not work, lack of frost, cold. The freezer side is working fine.
Need to see if the damper is open inside the fridge.  This the vent in to top left hand corner.  If it is not open then the damper needs to be replaced.  If it is open then one of the return vents (lower part of fridge) is blocked/plugged.  Let me know what you find.
Oct 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
WONDERING WHY MY GE GSS22SGRB SS REFIGERATOR ISN'T GETTING COLD, ALTHOUGH THE FREEZER SEEMS TO BE WORKING PROPERLY.
you should have a dial or knob that says freezer colder or warmer if so turn it for freezer to get warmer thast should allow cold aiur from freezer to enter into ref. that should make ref. colder. if to cold then dail it back a little at a time till ref. is what u like. ok try that. later gator.
Feb 15, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
Very loud vibration sound in the freezer
The fan is hitting on ice built up in the freezer..
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side works, but refrigerator side is warm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Dec 25, 2010 | Jenn-Air 48" Side-By-Side Built-In...
GE Refrigerator-Freezer side works fine/Refrigerator side not ok
You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
Please rate solution and make it worth the while to summit solutions. Thanks
Aug 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Compressor clicking on/off - freezer and refrigerator losing cold
I have a side by side frigidaire refrig about 4yrs old, but lately the freezer is not getting near as cold. My built in gage says it is a t 17-20 deg F even after I try to program it to 1 deg.
Apr 15, 2009 | Frigidaire FRS26R4A Side by Side...
Have side by side refrigerator (approx. 10 yrs old). Fridge no longer keeps food cold enough even at highest setting and freezer isn't as cold either.
Your refrigerator needs to be turned off and aompletely defrosted. Overnight if possible. You have a large amount of ice built up on the freezer coil that is blocking air flow.
Most refrigerator sections are only cooled by air flow from the fan in the freezer section.
Thaw it and clean it out real good and you should be back in business.
Jun 10, 2008 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
93 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
