Question about Edirol UA-4FX External Sound System
No sound on laptop
Just recently I had someone install a new hardrive on my laptop and when I got it back the sound would not work through the speakers or headphones. I've tried reinstalling drivers and even had it checked internally to make sure nothing was disconnected. Does this mean I need a new sound card?? can I install it myself?? or do I just need a new laptop?
There is no sound in my laptop
Posted on Apr 26, 2008
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
I got an old laptop and I bought a new toshiba laptop I just wanna ask how do I transfer my application and files from my old laptop to a new one using external hardrive,also wat external hardrive,and also...
You can transfer the data files only from the old laptop to the new one. You cannot transfer the installed applications/software. Software are required to installed again on the new laptop afresh.
To transfer the data you can use external portable hard disk, which can be connected to the PC using any USB port (just like pen drive) and you can copy - paste the required data to the external disk just like you copy data from one partition to another. After copying the required data, you can connect the external drive to new laptop and copy the data to the new laptop. You can use external drive of any brand/ capacity. However, it is better to have an external drive with larger capacity, so that you can transfer the data in one go.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Toshiba Computers & Internet
I replaced my hardrive and now there is no sound. UNder the control panel under sound/audio it reads no audio device
Sometimes the drivers aren't automatically updated or loaded when you install new hard drives. What I suggest is you download the sound drivers again for you Toshiba Satellite A135-S2276 laptop. Click here for the link to download site. All you have to do is enter your Operating System ( e.g. Windows 7, Vista, XP ) and you will click on the sound driver and download it.
Hope this helps and thank you for choosing FixYa.com
Apr 24, 2010 | Toshiba Satellite A135-S2276 Notebook
Bios not recognizing new hardrive
Hi:
Some older laptops don't always recognize the full size hard drives bigger than 134 Gb, but they usually show up in your bios. There isn't an easy way to install it wrong, so if the drive wasn't new to you, it might have a problem...New Hard drives come with installation CD's, but that won't do you any good until the drive is recognized
Nov 24, 2009 | Office Equipment & Supplies
Mx6128 gatway hard drive
The smallest hard drive that can be purchased is approx. 100Gb. You need a Windows installation CD, and provided you have the product installation code (it should be on a Windows label on the bottom of the laptop) installation is fairly straight forward. You may be able to get a Windows CD from a computer shop, they may install Windows for you at a cost. You need to download the device drivers for the laptop from the Gateway WEB site.
Jun 05, 2009 | Gateway MX6128 Notebook
Installed new hardrive on our Compaq laptop, question
Hi there.
Just make sure the boot order is set to the CD/DVD, you can do this by going into the bios or pressing F12 while the computer starts up.
please post back if you need any more assistance.
Regards
Jun 01, 2009 | HP Compaq Presario F730US Notebook
I have recently had a new hardrive put in my compaq v6000 and my laptop will not play any sound
Dear you are fishing a problem with sound whit-out change any type of hardware just parches
USB TO SOUND CARD OK just install in use port and after install driver and working ................ok
save money and time ok...........both of important
Jan 31, 2009 | Compaq 113897-002 - PCI Sound card
How to fix and install the built in microphone of my acer laptop aspire 4720z
If the sound has worked on this machine after the new hard drive was installed, then all you need to do is a system restore from the start menu, acessories/system tools. You may need to go back a couple of restore point in order to get it back, but this should do the trick. If it hasn't worked since the new hard drive was installed, then ou will need to go to the manufacturer's support site and download the drivers.
Aug 20, 2008 | Computers & Internet
No sound on laptop
when it is just the onboard sound it is AC97 from realtek you need. You can find the download for AC97 on line . just google it and you are done.
Apr 26, 2008 | Compaq Presario 5000 PC Desktop
Cannot Load Windows/Windows Setup Does Not Detect Hardrive
Harddrive is most likely bad get another and install windiws... if you found the right place they could "ghost" your information onto the new one!
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Edirol UA-4FX External Sound System Logo
59 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
