Question about Motorola Mobility RAZR V3xx Cellular Phone
I dropped my cell phone on the floor the screen now looks like the white fuzzy screen on a TV when it is off the channel, I can still receive phone calls and they can hear me but I can't hear them. I have turned it off and on, also I have took the battery out and put it back in. Thanks Tina
    Genius:
  • 1,478 Answers
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
On the other hand, the problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Posted on Aug 03, 2010
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
All I can get is a white fuzzy screen neither remote will work
I saw your post, kimlucasmill, and wanted to help you get that fixed! If you're using an HDMI cable for the connection between the receiver and TV, make sure the TV is on the HDMI input. If it's a component or AV cable, make sure it's on the respective input of those two. In the event that you're using anything other than those, such as a basic coax cable, make sure the TV is on the correct channel, perhaps channel 3.
Hope that helps!
Sep 18, 2011 | DISH Network IR Remote Control
Picture is fuzzy on dish network
Hey there!!!! You have probably gotten this resolved, no one wants to look at a fuzzy screen for too long! But here are some steps to help you out in the future, or if this has not been resolved yet. Of course, make sure that the receiver has at least a green and orange light on the front. If you are at the TV1 location, you will want to make sure that the tv is on channel 3 or 4, and sometimes that tv needs to be on an input. Usually that input is something like Video 1 or @, etc.. If you are in the TV2 location, you will want to make sure that the tv on channel 60 or 73. If neither of these work, try unplugging the receiver from the power source for 10 seconds. I hope this helps!!!!!
Becki Barned
DISH Network Customer Service
Dec 29, 2010 | Panasonic TCP50G25 50 in. TV
My RCA has a black block come up in the bottom of the screen? We have Dish Network Satellite and have programed the remote from the remote code guide. TV volume and channel changer work, but picture is a...
This has hopefully been resolved for you, but if not, here are some steps to go through. The black box that comes on the screen is usually signaling that closed Captioning is activated on the tv. Closed captioning does not run through the DISH Network receivers, so you can turn that feature off in your tv settings. The fuzzy picture could be a few things. You will want to check that all of your cables on the back of the receiver box and tv are tight as possible, and also make sure that the tv is on the correct channel. If you are in the room with the receiver, the tv will need to be on channel 3 or 4, and sometimes an input; usually video 1 or 2. If you are in a number two room, where there is no receiver, than you want to make sure that the tv is on channel 60 or 73. I hope that this helps!!!!!
Becki Barned
Sep 11, 2010 | RCA F36650 36" TV
Dropped on hardwood floor can still make and receive calls but external scrren pure white and internal black
Hi there
Your screen hit the wood badly that is why you have a black and white screen..
The solution to this problem is to fix a new screen for your phone .
Cheers!
Jul 03, 2010 | Cell Phones
I dropped my blackberry bold 9700 and the screen is white what does this mean
I'm sorry, but the LCD is broken. The good news is that Blackberry Bold LCDs are fixable. You can do a mail order repair or find someone local to fix it. Inovagent can repair your Blackberry locally in the Washington DC/Baltimore area.
Feb 07, 2010 | RIM BlackBerry Bold 9000 Smartphone
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
Apple iPhone Smartphone
telecharger and installer this program i phone PC Suite in this set
http://iphonefreakz.com/2008/08/20/iphone-pc-suite-compatible-with-firmware-20/
and pronsh your phone with one usb verifier if your phone
is connected in the programe
Click in system. Fix startup…..
Jan 23, 2009 | Apple iPhone Smartphone
Mobile Phone Problem
sound like a hardware fault, can you drop it into a repair shop for further advise?
Feb 19, 2008 | Samsung SGH-E900 Cellular Phone
White Screen
This phone needs a new flex cable.
Any question please email me.
Dec 11, 2007 | Motorola Mobility V710
Motorola Mobility RAZR V3xx Cellular Phone Logo
77 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
