Question about Daewoo DWC-073C Air Conditioner
Missing thermostat knob - Daewoo DWC-073C Air Conditioner
Oven not working
Gas stove check gas oven safety value
Mar 17, 2014 | Ariston Technologies Ovens
My Gas water heater details are as follows: Manufacturer: RHEEM, Model No: 311170N0 Problem<: I followed the instructions to light the pilot. After loghting the pilot I released the thermostat...
Allow the pilot to burn at least a minute, before turning the control knob to ON. You may have to push the knob in slightly to turn it counterclockwise.
Hope this helps you.
May 03, 2011 | Heating & Cooling
My dryer won't heat and the control knob doesn't move are they the same problem or is it the heat relay and where is the relay?
Which knob? The temperature knob or timer knob? If you're refering to the temp. knob, that's your answer! Dryers don't have a "relay". They have a thermostat and "Thermal Fuse". The fuse blows in case the thermostat fails and doesn't shut the heat off.
Dec 13, 2009 | Dryers
Knob missing for Miranda M800 Tripod (portrait Flip plate axes)
i have a miranda m-800 tripod no longer needed it has a knob broken but i still poses it can this help paul pjw6@talk21.com
Jun 04, 2009 | Slik U-212DX Tripod
Removed dial knobs, put back on oven doesn't work
possibilities are that the spindle retaining clip is missing giving the impression that the oven thermostat is being turned when infact it i s slipping, or the oven is in auto mode if timer model.
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Zansuai
If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Nov 07, 2008 | Zanussi TC7114W Electric Dryer
Zansuai
Nov 07, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Thermostat
I have seen some thermostats that have a ceramic stem attached to the inside end of the control shaft. The ceramic stem is non-conductive and heat-resistant. If this stem is broken or missing, then turning the knob will have little or no effect.
The solution is to replace the thermostat.
Feb 21, 2008 | Honeywell HZ2110 Utility Heater
ARISTON OVEN
I have two sources that give correspondances between thermostat numbers and temperatures.
This is the first one:
THERMOSTATS
bullette1.gifThermostat 1 30°C - 85°F bullette2.gifThermostat 2 60°C - 140°F bullette1.gifThermostat 3 90°C - 195°F bullette2.gifThermostat 4 120°C - 250°F Gas mark 1/2 bullette1.gifThermostat 5 150°C - 300°F Gas mark 2 bullette2.gifThermostat 6 180°C - 350°F Gas mark 4 bullette1.gifThermostat 7 210°C - 410°F Gas mark 6 bullette2.gifThermostat 8 240°C - 460°F Gas mark 8 bullette1.gifThermostat 9 270°C - 520°F Gas mark 10
The other one is a formula: t = 20 X (T + 3)
where t is the température in °C
T is the thermostat (1, 2 ... 12)
As you may discover, each of the methods give slightly different results. Hope this will help.
Nov 14, 2007 | Ovens
Daewoo DWC-073C Air Conditioner Logo
29 people viewed this question
Top Daewoo Heating & Cooling Experts
Steve
old fart58
armandog07
armandog07
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
