Question about Garden
I have a fl 1500 weedeater and the pull cord is stuck all the way out. How do you fix this problem>
    Problem Solver:
  • 10 Answers
Take out the spring and recoil it then put wd 40 on the spring and rewind it and that should take care of it.
Posted on Aug 04, 2010
  • Adam Kelker
    Adam Kelker Jun 26, 2011
    I had a similar problem with mine that I inherited from the garbage. These guys have an inherent problem from the manufacturer materials. You will find one, the heat of the motor has caused the recoil to drag against the top of the motor. The solution is simple. Add a washer that just screws on to the screws between the upper guard and the bottom of the motor. If that doesn't work, add two. You may have to add a washer or two between the fan and the spacer as well. Problem solved.
    Secondly, the air filter cover may be warped and won't seal. Heat it up carefully with propane and draw the hole back out and cool. Next, take a dremmel sanding drum and remove about 1/32 inch from the contact point that it screws into (removed from the carb to keep from clogging the carb). Reassemble and you are done.
    I also readjusted the fuel idle mixture screw by bending the tab down and making sure it was about two turns out and rebent the tab. I also tensioned the recoil a couple more turns to give it a little more zip.
    I just did both of the repairs to mine along with a total cleaning of the carb as well as replacement of the carb hoses and this guy runs like new, far better than I would have imagined. The recoil no longer jams, not even partially. No oil or lub necessary as the problem wasn't dirt, it was binding from a warped housing.
I have a 150 mph Weedeater FL 1500 LE that will start but not continue to run. How can I fix it.
Make sure your fuel lines are in good condition and your air filter is clean. If this does not work, may need more involved repairs.
Nov 01, 2016 | Weedeater Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
Aug 11, 2012 | Weedeater Garden
The pull chord is jammed on my FL 1500 LE. How do I get it loose?
Unfortunately,its not jammed,you need a new starter clutch mechanism,I have a similar problem,if you can get one from your agent/supplier its quite easy to do yourself,you should be able to download a pdf manual from the internetrgds
Sep 26, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
Replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Sep 09, 2009 | Garden
Garden Logo
385 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
