VGA to TV S-Video Converter & RCA Cable Adapter
  • arbaltzell Apr 25, 2008
    How can I tell if my computer is compatible with this product?
Call the guys at www.showmecables.com They have a host of products that will convert from PC to TV and back.
Posted on Apr 26, 2008
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
How can I hook my dell latitude e6400 lap top up to old sony Trinitron with one vga cable connected to laptop has rca and s-video also on same cable only one side thoe
If I understand your configuration correctly, you have a VGA cable that plugs into your laptop and you want the other end to connect to your TV? They make a VGA to S-video converter box that you can buy to make the connection http://www.bestbuy.com/site/agptek-vga-rca-s-video-to-vga-converter-box-adapter-switch-for-pc-lcd-monitor/1308798590.p?id=mp1308798590&skuId=1308798590
Sep 23, 2013 | Dell Latitude E6400 Notebook
I want to connect my computer to sony wega triniton kvxr29m80 from the hdmi or vga port to the tv's component or 3rc ports. is it possible..i have tried the hdmi to component cable and it does not...
An HDMI to component video cable will not work. These are meant for projectors that work with computers and have only component in jacks.
You will need is a VGA to Composite video converter, VGA to component video converter or HDMI to component video converter. These translate the computer output to the input the TV will understand. Here are some VGA to component video converters: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html . (The exception is if your computer has a TV-out port. In this case, you need an adapter that looks like an S-video plug that will then have composite or component video jacks.) If you want to use the TV speakers, you will also need a 3.5 mm to 2 RCA audio adapter (either M and F/F for an RCA cable to the TV or F to M/M for a 3.5 mm audio patch cable) or cable (3.5 mm M and M/M RCA).
I hope this helps.
(A computer gives RGB output on the VGA cable; the TV reads PbPrY on the component video. Thus you need for the converter rather than a simple adapter. Similar communication differences apply on the HDMI signal.)
May 11, 2012 | Sony Televison & Video
Conecting computer to view screen
Hello
Your JVC Tv has AV & Component video inputs only. No direct connection facillty with computer is there. Computers outputs VGA stream video. VGA stands for Vodeo Graphics Arrey. This video stream cannot be connected directly to your JVC set. There are sets, which have this facility, but your set have not.
If you want to connect this set to computer, you have to buy one converter [VGA to RCA out], from open electronic sparepart selleing shops at your town. It will not cost more.
If you have this converter, you can connect your computer directly to the VGA converter, using a VGA to VGA cable, and the output from the converter by RCA connecting wire to TV. In short, the converter will be in between TV and Computer.
VGA to Video converter will look somewhat like this. OK.
Dec 14, 2011 | JVC AV-32D305 32" TV
What cable do I need to connect my Sony vaio VGN FS640 Laptop to my RCA TV and where does this cable connect to, on my laptop? My RCA TV has a SVideo connection.
To output video from your laptop you will need to use VGA out.
What you want to buy is a VGA to S-Video adapter, making sure that both the VGA and S-Video have male connectors.
This solution will not output audio.
Mar 06, 2011 | Sony VAIO VGN-FS640W Notebook
No problem, wondering if I'm able to connect this TV to my laptop to connect to the internet and if so what do I need to do this.
Yes, you should be able to. You will need to buy a $20 adapter. Sewell Direct sells them, also Amazon.com. They are called VGA to RCA composite video converter. This will convert your laptop's VGA output to RCA composite video for connection to your TV yellow video input. Connect an audio cable from laptop's earphone output to the TV's RCA audio inputs (white and red) using a 3.5mm to RCA adapter cable available at Radio Shack for about $10. This will work. You can see everything that the laptop displays on the TV. You can even hookup a VCR to record it all.
Aug 04, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Need to get a torpedo projector to work with laptop
Unfortunately, there is no simple VGA-to-RCA adapter cable if you're connecting to a composite video input (usually colored yellow) or s-video input. VGA output is separate red, green and blue video and synchronizing signals, and they all need to be combined. You need a VGA-to-video converter to do this.
If the projector has component video input jacks, then you can buy a simple adapter cable.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Radio Shack Cinego D-1000 Multimedia...
I have a laptop and a tv. I would like to hook my laptop up to the tv. The tv does not have a slot for a VGA CABLE and my laptop does not have a slot for an RCA CABLE. What can I do to connect the two?
You need an Video out, adapter cable, for your model Laptop, IF yours indeed does have the ability to TV out, the "output" is "Composite Video" and goes into the Composite Video "IN" on the TV. Audio is taken from Line Out in laptop & goes to AV audio in, via a Phono Jack to RCA converter plug. Also it must have correct drivers and be enabled and have desktop extended to the TV either Cloned or Spanned.
Usually one connects up to the TV, powers TV on & then Turn your laptop on.
You may have a Yellow RCA socket on the back/side of your laptop, otherwise you have to get a converter cable.
Feb 07, 2010 | Compaq Presario Notebook
Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Dec 23, 2008 | Dell Inspiron 1501 Notebook
Ati mobility radeon 9000 agp
hi camperd55,
I believe you have the right adapter cable. According to my knowledge the Radeon 9000 supports TV output via RCA (check http://ati.amd.com/products/MobilityRadeon9000/index.html:" Mobility™ Radeon™ 9000 provides the highest quality output support for DVI-I, TV and CRTs.")
Firstly, it would be a good idea to make sure your TV has the 3 RCA jacks into which you will insert the adapter cable's 3 RCA connectors according to the colors of the connectors and jacks.
Secondly, if your laptop has a VGA port, you're set to connect your laptop to your TV, no hustles. If your laptop doesn't have a VGA port, your going to have to get a DVI-VGA converter, so you're setup will be something like: [laptop]-[DVI-VGA converter]-[VGA-3RCA adapter cable]-[TV's 3RCA jacks].
When you get your laptop's screen displaying on your TV, its merely a matter of using your recording equipment to record the TV's image as you would any program showing on the TV.
I hope this will help you solve your problem, thank you for using the FixYa service.
Kind regards
Henru : )
kind regards
Feb 10, 2008 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
