Question about GE Dryers
I have a GE 5 cycle automatic electric dryer. It sqeeks and its not heating properly. What should I look for? The model is 123C7939P001 or 175D1550G119. Also the timer sometimes works.
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
mrgreenz
  • 962 Answers
SOURCE: GE 5 cycle automatic heavy duty dryer
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
Posted on Nov 08, 2008
  • 71 Answers
SOURCE: GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Posted on Dec 21, 2008
dealt_soul
  • 296 Answers
SOURCE: GE Electric Dryer Heats up but does not automatically turn off
Change the sensor in the drum. Theres a sensor that tells it if there is moister in the enclosure.
Posted on Feb 12, 2009
  • 1122 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
Thiers no heat and thiers a sqeeking noise
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 02, 2011 | Maytag Dryers
No heat during either drying cycle automatic
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Feb 15, 2010 | GE DVLR223 Dryers
How do I change the heat element in a hot point dryer ,Model number 123C7939P001
the number you have provided is not the model #. open the door and look around the hole for a proper model #. then I can help you. tks
Oct 11, 2009 | Dryers
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer does not automatically stop, takes too long also.
you need a timer you can probably take the old timer in to your local appliance part store and get a new one
Apr 20, 2009 | General Electric DHDSR46EGWW Dryer
Dec 21, 2008 | GE DPSR610GGWT Dryer
Aug 21, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryers Logo
81 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
