Question about First Alert PIR720R 360 Hands-Free Light Socket with Motion Sensor
I have a First Alert FA260 alarm system and I do not have it monitered by any company. There is a "bat" symbol on the keypad. I located the user manual online, but it only tells me that I need to replace the battery which I already figured. It doesn't tell me how to change the battery. I took the panel off but I don't see any battery or don't know what I'm looking at. Can you help me?
  • 1,557 Answers
In the bottom of the cabinet, you’ll see the backup battery, connected to the main board by a red and a black wire. Normally these wires have connectors that plug onto the battery posts. Take a look at those connections, which should be tight and clean. If you see an accumulation of chalky gray powder around the terminals, you may have to replace the connectors as well. That’ll depend on whether the old connector #after cleaning with an old toothbrush# is in good enough condition to re-use.
The next step is to find the battery specifications. Look at the hookup diagram on the inside of the cover. You’ll usually find the specifications there. If the diagram is missing or does not have the specs, you can get them off the old battery itself. Here’s what you’ll need.
There are three parts to the specification: voltage, capacity, and battery type.
The voltage is the easiest, and most alarm panels use 12 volt batteries.
The capacity will be listed in either ampere hours #abbreviated aH# or milliampere hours #abbreviated maH#.
The battery type refers to the chemical composition of the battery. It’s important to select the correct type because the charging circuit is designed for that type. The common types are Nickle Cadmium #NICAD#, Sealed Lead Acid #SLA#, and Gel Cell #GC).
With this information in hand, you can shop the Internet for a replacement. Perform a Google search for “alarm battery” or “DIY alarms.” You’ll get several vendors, each with a means to drill down to batteries. You’ll find several different brands as well. You don’t have to get the same brand that you had, but the specifications need to match. Voltage and type must be an exact match. The capacity can vary a bit. For example, if you have a 4 aH battery, a 4.5 aH battery will be fine. Just keep in mind that the higher the capacity, the larger the battery’s dimensions will be. While there’s usually plenty of space in the cabinet, getting an 8 aH battery to replace one that’s 4 aH will probable not fit in the cabinet.
Once you get the battery, replacement is as easy as unplugging the old one, and plugging in the new one. It will begin to charge immediately, and any trouble condition should clear within a few minutes.
Posted on Aug 03, 2010
2 Suggested Answers
ford_67
  • 34 Answers
SOURCE: first alert fa260 security system
Sounds like a low battery.
Posted on Aug 24, 2008
How do ADT alarm systems work?
ADT is the largest provider of the home security system. It is a well-known brand in the world and everyone knows about this company. It works that sensors are triggered, they send a signal to your security system control panel, which will alert your ADT monitoring station and there is the two sensor pieces are in contact with each other while the door/window is closed. When they are opened, the sensors separate and an alarm is triggered. It is the best home security provider company as other home security companies. I fixed home alarm system in my home from this company.
Feb 13, 2018 | Home Security
Tip
GSM alarm system with RFID & APP control and Touch keypad
Name:GSM alarm system with RFID & APP control and Touch keypad
Memo:
products introduction
??Features:
??Multi-languages voice; system volume is adjustable (low, medium and high);
??99 RFID cards to arm, disarm, and control the relay;
??SMS notification for disarm by RFID card; SMS content (of the first 10 cards) is editable;
??12-second voice message: by control panel or remotely;
??Broadcast system time and play voice message;
??Use panel as a telephone to make calls;
??Set the by control panel, SMS or remote calls;
??10 remote controls, 99 wireless and 2 wired defense zones;
??Sensor low power alert and tamper alert;
??Some of SMS alarm contents are editable;
??SMS alert for control panel tamper, low power, power failure/ recovery;
??Remotely control the relay.
REV M White SUNRAY 800 HD SE SIM 2.10 Card SUNRAY DM800 HD SE A8P ALPS M Tuner SUNRAY DM800 HD PVR SIM210 with Wifi HDMI SIM 2.1 Cable receiver.SUNRAY DM800 HD SE A8P card SUNRAY DM800 HD SE A8P card ALPS M Twin Tuner SUNRAY DM800 hd Pro Alps Tuner REV M SUNRAY DM500 hd Pro satellite Receiver ,wholesale cheap discount price.alarm security systemVU SOLO 2 SE Twin tuner SOLO MINI 3LED DisplayLED signLED Display ScreenOUTDOOR LED sign large LED DisplayOUTDOORLED SIGN BOARLED DisplayFlexible CurtainLED Dance Floor Display FullCOLOR OUTDOOR Led Sign led screenoutdoor led displayled displayindoor led displaytransparent led displayled display lightingled video wallchina led displayfull color led displayled screensflexible led screenrgb led displaylarge led displayled curtainled dance floorfull color led displayout door led displayled display manufacturerssmd led displayled dance floor for saleled display, led curtain, led mesh for stageoutdoor led screenadvertising led displayindoor led displaystransparent led screenled meshled displayled screenA8p card SUNRAY SR4 V2 Rev.E jynxbox store
dreambox dm800 hd se v2alarm security systemdreambox dm7080dreambox dm7080dreambox dm820dreambox dm7020 hd v2cheap wholesale dreambox dm800 hd v2Sunray SR4 V2 Sunray SR4 800 se Sunray SR4 hd se JynxBox Ultra HD V14JynxBox Ultra HD V16JynxBox Ultra HD V15Dreambox DM7080 HD PVRDreambox DM820 HD PVRDreambox DM8000 HD PVRDreambox DM7020
on Mar 29, 2016 | NU -set Gsm Padlock Alarm System -...
What does check 11 means on my First Alert FA260 alarm system.
what does check 10 motion mean on my First Alert FA260
Mar 20, 2013 | First Alert Fa260 Keypad
Alarm beeping on Broadview alarm systerm
Is the beeping coming from the keypad or elsewhere? Do you know which model system you have and what kind of keypad and sensors? The more info you can provide the better.
Mar 07, 2013 | Kidde DC Voice-Alert CO and Smoke Alarm
How do I set my alarm, I have the code for it but no instruction manual
You can just enter the code on the keypad and the system will arm in 'away' mode, meaning it will arm all zones and it will expect there to be no one in the home or business The keypad should beep and show that the system is arming up. If it does not, then you didn't enter a valid user code and you will need to contact your alarm installing company to provide you with a valid user code, but also it appears, some information on the use of the system.
Mar 06, 2011 | DSC Pc9155cp01 Alexor Wiress Alarm Panel...
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
Our Ademco 6160 PL3 alarm system keypad has an error message
It is located inside a tan colored metal box 12"wide by 15" tall and 4" deep; unless it is flush mounted, then only .5" deep. inside you will most likely find a 12 volt 4 or 5 or 7 amp hour battery. Note; the door may have a lock on it. I have found the key on top of the box, in the lock, and unlocked. The box could be located anywhere but, many times in closets, utility rooms, garages, crawl spaces, etc.
Nov 01, 2009 | Honeywell 5804 Ademco Wireless Security...
I have a First Alert system to which I do not have a security company servicing it. My problem is if I open certain windows either the big alarm sounds or the panel will go off beeping every hour where I...
If you want to kill the system, you need to remove its power. First remove AC power by unplugging the alarm's transformer (should be close to the "connection box"). These transformers are often screwed into the outlet to make them harder to remove, so you may need a screwdriver to do this. Next, disconnect the backup battery (located inside the "connection box") by pulling the negative lead off of the battery. This should disable the system.
Sep 12, 2009 | First Alert Home Security
First Alert PIR720R 360  Hands-Free Light Socket with Motion Sensor Logo
5,010 people viewed this question
Top First Alert Home Security Experts
charlie rodriguez
charlie rodriguez
Ronny Bennett Sr.
Ronny Bennett Sr.
woodzowl307
Are you a First Alert Home Security Expert? Answer questions, earn points and help others
