Question about GE Spacemaker JVM1640SJ Microwave Oven
The lights that are under my microwave and that are lighting the cooktop below are no longer working. Do you think a repairman would be able to figure out the wiring and fix the lights. It is a top of the line profile microwave that was installed before I bought the apartment.
    Problem Solver:
  • 7 Answers
It could have an internal fuse. If you have the manual check and see if there is any mention of one. If you don't have the manual do an on-line search using the make & model # of you unit.
Posted on Aug 03, 2010
Hotpoint microwave model RMV1435BD under recall??
None to my knowledge, but common faults include keypad failure (may show error code "F3") and cooktop light failure, both of which can be affordably repaired. (See link below)
For more free DIY and other help & advice, feel free to contact me via my site below.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 14, 2017 | Hotpoint Microwave Ovens
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
TYPE BULB FOR PANASONIC NNP295 COOKTOP LIGHT
Halogen Cooktop/Night Light Replacement
Be careful as the Cooktop Light Cover and the bulb may be
hot.
1. Unplug microwave oven or disconnect power.
2. Loosen the screw to open the Cooktop Light Cover.
(Be careful not to lose the screw.)
3. Replace the old bulb with a new one.
(use Max. 125 V, 30 W, Wide Pin Capsule Type/GY8.0~9.0
recommended)
do not touch a new Halogen bulb with bare hands.
Fingerprints may result in shorter life. Remove fingerprints
with alcohol.
If this bulb is not available locally, contact your local
Panasonic dealer. Part number is F612E6Z00AP.
4. Reinstall the Cooktop Light Cover with a screw
Dec 02, 2014 | Panasonic Microwave Ovens
How to change bottom light bulb
I have to assume that you are referring to the cooktop lamp.
Under the microwave there is one screw to remove to access the lamp. It is a 30 watt candelabra base lamp.
It shows on page 14 of the user manual below. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208185379.pdf
Aug 22, 2014 | Whirlpool MH1150XMQ Microwave Oven
Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
www.repairclinic.com
Apr 04, 2013 | Tappan Microwave Ovens
I have a Brandt induction cooktop and 2 hotplates don't work at all and the other 2 now don't appear to be connecting with the saucepan. Heat light starts to flash then turns off completely. Unable to...
Sounds like a wiring problem,take off of course with no power and check it out. No harm if no power,and replace wire and or componet with same.
Jan 11, 2011 | Brandt Microwave Ovens
Built-in Microwave Oven Over Cooktop
some keypad buttoms wont work and some do
Aug 08, 2008 | Kenmore Microwave Ovens
Spacemaker XL Microwave Oven MODEL JVM1640 Help
please check control circuitand related circuit and wiring mains fuse and related circuit
Oct 04, 2007 | GE JVM1640 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
124 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
