Question about Simplex Kaba Ilco Unican 1000 keyless lock
I have a unican 5 button keyless door lock. you enter the code and turn the knob to get in it is about 10 years old it has the the star shaped insert on the inside if the door and I know that has to be turned to change the codes but can't remember the rest of the steps
2 Suggested Answers
SOURCE: lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
Posted on Jun 26, 2009
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Is there anybody to help me? It's urgent please...
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Mar 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Hi, I have an older version of the Ilco unican corp pistol safe. IT is a simplex with the push buttons and a silver turner. I got it open, but don't know how to re program the code. Any help?
pctuneup191
REMOVE THE KEY.
Good Luck!
Feb 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
We are trying to change our code for ILCO, Unican Corp. keyless lock, serial # 743660000, model # 201049 USA (think it is model #) It appears we have lost the default code, how do we find a default code. ...
1.) ENSURE THE DOOR IS OPEN! This is totally necessary to reset the combination!
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Good Luck!
Jan 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How do I change the code on the Kaba IIco Unican 1011 keyless lock?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Customer service can be contacted from this link:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Good Luck!
Dec 21, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need to know how to reprogram the code on a Simplex Kaba IIco Unican 1000 keyless lock
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I NEED TO RESET THE SIMPLEX 5 BUTTON LOCK, BUT I DON'T REMEMBER THE CODE, HOW DO RESET IT???
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
this site:
aspx?id=13
Good Luck!
Nov 22, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Forgot code to Unican L1000 lock. How can you reset code?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Oct 29, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
Want to reprogam keyless lock unican push button lock please advise ------thankk you...
Turn knob once. Put in present combination. Open screw on the top, Use a small rod or drillbit  that will fit into the hole. Press straight down on a lever that is inside of the hole,until it clicks. Turn knob completely(once) to clear old combination. Put new combination in, making sure that a click is heard upon pressing each button.  Try knob with both the old and the new combination. Each digit may be used only one time in the combination.
Dec 31, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
444 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
