Question about E-Machines eMachines W2686 PC Desktop
Emachine w2686 no display when boot up
Emachine proablem when i start it up notthing show up on the monitor and the motherboard seems to be working fine.. almost out of ideas
  • Anonymous Jan 12, 2009
    Same problem..tried memory, cmos reset etc..even tried video card...although it seems like its running...just no video...You think processor ?
    Scholar:
  • 186 Answers
Couple things to check. First, check with different monitor. Their monitors are usually build by KDS and I think there was a bad series out there. Also check for any beep codes through speakers on startup, this can tell you bad ram or bad video out. Also try unplugging computer and removing CMOS battery inside (watch like battery). Lastly, If non of the above, a bad processor will allow the computer to come on but no beep, no boot, no nothing but fans and green power light. Hope this helps a little.....
Posted on Apr 25, 2008
My eMachine Model W2686 CPU will not turn on. Is
it's not issue of CPU problem 1st chack your CPU Fan is working or not then only u can find the pro
Apr 13, 2010 | E-Machines eMachines W2686 PC Desktop
My desktop is displaying everything upside down?? its vista
Hold down CRTL + ALT and the up arrow and that should rotate the display to the right direction.
Jun 27, 2009 | E-Machines eMachines W2686 PC Desktop
W2686
Your problem would not be with a battery, but the power supply. Try plugging into a different outlet just to make sure, but sounds like you may need a new power supply.
Jun 11, 2009 | E-Machines eMachines W2686 PC Desktop
I have an emachines t5226 with vista. it will not boot.the fans run and that's all it will do. the dvd drive spins but won't read the boot cd. when the computer crashed I turned off the power strip and...
hi! if your pc is still powering then theres no problem with the PSU, if your pc boot and have a display on your monitor then theres no problem with your VGA card and RAM but if your PC don't have display then you must check your VGA and RAM it maybe a faulty hardware. and next thing you do is check if your HDD is stillworking and make sure you have a bootale CD with you..good luck
Jun 10, 2009 | E-Machines eMachines W2686 PC Desktop
Emachine destop not recognising acer lcd monitor
It sounds more like the computer isn't starting up. The "no signal" message is coming from the monitor itself to tell you it's on but there's nothing coming in to display. Normally no special drivers are required for the monitor, and you'd see at least the computer maker's splash screen and BIOS messages if the computer was starting up properly.
You'll need to determine what is keeping the computer from starting up. Make sure it's getting AC power and that the power light comes on when you press the front panel power button. You may need a power supply. If the computer comes on but doesn't boot you may have memory problems or trouble with the motherboard. But your monitor is working properly.
May 10, 2009 | Microtek C593 15" Flat Panel LCD Monitor
I have a emachine w2646. I went to turn it on and nothing. The green light is on and the monitor works. I switched to plugs and even went a brought a new power supply. The green light only come on. What...
you could replace your video card.but it could be a motherboard problem as well.if your card can be removed try it in another pc.you could also try resetting the computer bios.
Mar 01, 2009 | E-Machines eMachines W2686 PC Desktop
Monitor problem
Okay if your keyboard doesnt come on, then you shouldnt be able to get past the BIOS screen. Second does the motherboard come with on board VGA??? If so the try sticking a external VGA card in and see if that wont get your screen to work. I know it will cost you, but theres not much you can troubleshoot with a monitor if it wont come on.
Oh you can also try booting into safe mode, if you are able to get that far.
If you can get into safemode, my bet would be that you have a driver problem.
And how are you able to see that everything else is working if the monitor wont come up???
Anyway give it a bash and see any of this helps.
Good luck.
Jan 14, 2009 | E-Machines (308714) Motherboard
My computer do not start
Does it work if you put the old RAM back in?
If so, I'd say the new RAM you got is bad.
Nov 04, 2007 | E-Machines eMachines W2686 PC Desktop
Emachine W1135
when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
Oct 17, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Computer will not boot up at all
Emachines have had a lot of problems with their power supplies going bad and destroying the motherboard in the process. If you can, start looking for a replacement motherboard (on eBay) and a larger wattage power supply (any local computer store) especially if you have experienced the computer shutting off or rebooting for no apparent reason. If you're lucky, you can try booting into safe mode by pressing the "F8" key on you keyboard during the boot process and select safe mode from the menu. If your computer boots up, then there exist the possibility of a corrupt video driver and/or corrupted file system. If you still can't boot and experience the same thing, then you may have a physical hdd problem or again, power supply, motherboard, or both. Also, do not over look the possibility of an internal fan on the video chip not turning. I hope this helps and good luck.
Jun 10, 2007 | E-Machines eMachines W2686 PC Desktop
E-Machines eMachines W2686 PC Desktop Logo
629 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
