Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Why does the intake hose pinch? - Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
  • Intex Master
  • 8,404 Answers
It is weak ... being pinched by excessive suction ... or the hose is weak ... Im leaning toward weak ... replace it.
Posted on Aug 04, 2010
2005 escape 3.0 V6, disconnected battery lead, removed upper intake manifold to replace spark plugs bank 1. Replaced manifold and all hoses, reconnected battery. Now transmission has slow shift.
check that you replaced the vacuum hose from the manifold to the actuator on the transmission
check that you have not caught it under the manifold and pinched it
Jan 22, 2017 | Cars & Trucks
My 2000 F250 5.4 idles 2500!! I unplugged the IAC and it dies plug it back in and pinch the vacuum hose off and it idles donw normal! So I changed it and it still does the same thing and I check for...
Fords are bad for Idle. Pinch the hoses of again. One at a time. When it idles normal. follow that line to find the leak. Ford has and still does have bad rubber elbows. They can't take the heat and oil. Most the leaks I find are under the intake plenum.
Oct 10, 2014 | Ford F-250 Cars & Trucks
What causes air hose collapses and gets pinched off of 2002 mountaineer. around intake carb area
Collapsed hose indicate the pressure on one side is much lower than the other, in this case the intake or suction side is very strong and since the air its pulling into the engine is not sufficient i.e. both sides are not equal, the hose collapses. Most likely you have an air restriction in the hose someplace, could be a really badly clogged air filter, or an obstruction in the air intake at the front of the vehicle where the air intake scoop is. Check that line carefully you'll probably find something in there someplace.
Aug 12, 2014 | 2002 Mercury Mountaineer
ENGINE IS SURGING AND WONT IDLE
The MOST LIKELY cause of an engine surging and refusing to idle is a vacuum leak. Check all vacuum line connections. You can also pinch rubber vacuum hoses off one at a time near the intake manifold to see if the engine idle changes, - don't forget to check the hose to the brake booster. If pinching off the booster hose fixes the running problem it is possible that the booster itself is leaking if you can't find any leak in the hose.
You can check for vacuum leaks at the intake manifolsd gaskets and throttle body base by squirting some carburetor cleaner around these areas. If you spray this into a vacuum leak area, you will hear a change in engine RPM.
Aug 16, 2011 | 1994 Chevrolet S-10 Blazer
Code 14 no start
error code 14
Faulty intake air pressure sensor hose
system; a hose is detached, causing
constant application of the
atmospheric pressure to the sensor;
or, the hose is clogged.
 Intake air pressure sensor hose is detached, clogged,
kinked, or pinched.
 Malfunction in ECU. 03
Jan 01, 2011 | Yamaha 1900 XV 1900 A Midnight Star
Motor races in park
use needle nose pliers and pinch each hose as close to the intake as you can, if not it may be the intake gasket
Apr 17, 2010 | 1997 Chevrolet Tahoe
Rancillio Expresso Machine won't pump water through. Makes lound noise.
Hi There are a couple of things. 1. Your pump is not primed. Open the steam knob and push the middle switch. 2. Your intake hose is pinched or not connected to the pump, or your intake hose is not in the water tank.
Feb 21, 2010 | Rancilio Silvia Espresso Machine
Heater will not switch to defroster orfloor just had a intake gasket installed then this problem started also wont switch to ac either
Your HVAC controls work off engine vacuum there is a vacuum hose that comes off the back of the intake plenum that is either off,kinked,or pinched.
Feb 21, 2010 | 2000 Chevrolet Blazer
Heating is not working. We have change the
Lower intake manifold could be gone or heater core plugged.
Dec 05, 2009 | 2001 Ford Taurus
Whirling sound coming from the engine
same problem on mine. i had a tune up done to the engine and they pinched the PVC hose from the air cleaner to the intake manifold. It was taken off and pinched backwards. Check the PVC valve and hose to make sure there are no restrictions
Dec 08, 2008 | 2003 Chrysler Town & Country
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
258 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
