Question about InFocus IN3106 DLP Projector
Infocus in3106 keeps showing me replace lamp message after i already did'it
    President:
  • 567 Answers
Hello there, you need to check the lamp connection properly it may not be properly fitted into position that can be the reason you get that message.
Posted on Aug 03, 2010
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    I replaced the lamp and keeps showing the replace lamp message on touchpad
    Hi there, you should check to see if the lamp is properly fitted in position because that can be the reason why the device is not recognizing it.
    Aug 03, 2010 | InFocus IN3106 DLP Projector
    Lamp did not strike
    You have problem whit the lamp. you should replace the lamp.
    Jun 01, 2010 | InFocus LP 600 Multimedia Projector
    About how many hours are left when the replace lamp message comes on?
    usually between 0 and 50, depending on how clean you keep the projector. if it's really dusty, the lamp could explode from overheating at any time.
    Feb 07, 2010 | InFocus ScreenPlay 7205 Multimedia...
    How do i find out if i need a new lamp for my infocus 4805. when i turn it on the fan blows for a cpl secs and the green light blinks a few times, but i dont get anything saying the lampis out
    when you power it on, do you hear a high-pitched whir? if not, you need to replace the colorwheel. it's also the colorwheel if you hear a buzzing instead. if the colorwheel does not spin, the lamp won't come on. if the colorwheel is ok, check the lamp. is the screen on the side of the lamp clogged with dust? is the inside of the lamp bulging, spotted, or foggy? if so, replace the lamp and clean out your projector with canned air. dust blocks air flow and keeps in the heat. this shortens the life of your lamp and projector. if you do need the colorwheel replaced, you could get the part from an infocus service center and do it yourself, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
    Dec 27, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Projector attempts to light the lamp, but to no avail
    the ballast is gone and needs replacing. unfortunately, infocus has no parts for that model.
    Oct 30, 2009 | InFocus Office Equipment & Supplies
    I have an Infocus SP5000. The unit turns on,but
    I use an infocus for my church. I don't believe there is a counter shut off, or a reset that would revent the light from operating. I sugest you go ahead and replace the lamp.
    Aug 17, 2009 | InFocus Televison & Video
    InFocus LP130 Projector has intermittent power off
    go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
    Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
    LP600 - Lamp Did Not Strike
    Check for shorted flat pack diode in power supply.
    Feb 04, 2009 | InFocus LP 600 Multimedia Projector
    InFocus IN3106 DLP Projector Logo
    61 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
