Question about Homelite Garden
Homelite walk behind string trimmer, starter rope, how to replace. Put on new rope, won't recoil.
3 Suggested Answers
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
rycgl
  • 1545 Answers
SOURCE: how do i remove starter recoil on a homelite st
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers.
Posted on Nov 11, 2010
Recoil starter pulley not retracting starter string. How do I replace it?
there is a spring that recoils the rope inside .not a hard task but rather tricky with the spring .good luck
Sep 09, 2016 | Garden
Replacing starter cord on stihl fs 70 R trimmer
Go to you tube. On top line repair starter rope on --------
Jul 18, 2016 | Stihl Garden
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
How do i fix a rope on the recoil?
You can get a replacement rope kit at Home Depot or any home improvement center. Mine was 3 bucks.
Aug 26, 2014 | Homelite 2-Cycle 26 cc Curved Shaft Gas...
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
How do I fix/replace the starter rope on a TB20CS (Tuffy Troy Bilt String Trimmer) that's broken? Do I need any special tools?
Probably no special tools needed. Take the starter assy off. Turn the recoil in the direction it will turn if you are pulling the rope. When it gets tight, hold it there and install the new rope. When it is installed, let go of the recoil and it will draw the rope in.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Troy Garden
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
Replace recoil starter for Homelite trimmer Model UT21546
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
154 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
