Question about Panasonic PT-AE700U Multimedia Projector
How reset panasonic ptae700u when you change lamp thank you
  • 57 Answers
Go into the menu under "Option" and reset lamp hours to zero
Posted on Aug 15, 2010
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
Tip
Procedure to reset Panasonic TVs
If you have replaced the lamp in your Panasonic DLP TV and are having problems such as a message on the screen telling you to reset the lamp timer or the unit not powering up, you probably need to reset the lamp counter. All DLP and LCD TVs which have high intensity lamps generally need to have a lamp timer circuit reset after a lamp change. The manufacturers want to give you a heads up prior to having a catastrophic event such as a lamp exploding which could cause a fire as well as other damage.
Therefore in many cases until you reset the lamp timer the unit will not operate or it will keep reminding you to reset the lamp timer which is very obnoxious. This is not a hard procedure but you will need the original factory remote to accomplish the task. Generally the procedure involves pushing a sequence of buttons.
I recommend placing a piece of masking tape on the rear of the TV with the date the lamp was changed to make it easy to remember when the next lamp change will be necessary. Also you could purchase a lamp now to avoid paying more in the future.
The following procedure should solve your problem:
1. Turn on the television.
2. Press the down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Oct 28, 2010 | Televison & Video
My PTAE700U Panasonic projector has a blue area going down one side of the screen. What wouls cause this and how can I fix? Thanks, Pete
hi,
first check is complaint is with ur projector or the source u ar using. just connect any other input to ur projector and then test. if then also the problem remains, there is some problem in ur projector circuit board or lcd panel. if so u should consult the manufacturer for assistance.
ok
Dec 22, 2010 | Panasonic PT-AE700U Multimedia Projector
Lamp light flashes on Panasonic PT-52LCX66
mikkhail75,
You should change the lamp. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the process and where to get the parts at the best price. Your panasonic may or may not need the lamp timer reset. Your manual should explain the process.
Thanks for using Fixya and for the great rating!!
hardrocko
Sep 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How to lamp reset in panasonic model no. PT-DW5100U (lamp model no. ET-LAD57W)
It's in the menu under "Option 2". Then look for "System Information" The lamp reset is there
Good luck
PS: Change/clean the filters too!
Aug 13, 2010 | Panasonic 2 Projector Lamp
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I want to know how to reset the lamd on panasonic
HI; The instructions will come with the lamp itself for your model Television, as long as the lamp was an OEM type lamp.(Original Equipment Manufacture)>>>
Dec 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
LAMP REPLACMENT
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Dec 23, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Replacement of lamp
please confirm that the customer closed lamp cover firmly because improper actuation of lamp cover safety switch will shut down the lamp.
Feb 14, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
208 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
