Question about Dell ADA425 2 Speakers
Only right speaker is working left doesnt sound
    Problem Solver:
  • 8 Answers
What has most likly happened in this case, is that either:
a) the wire has been tampered with, and has caused the left speaker to cut out,
b)the speaker settings are set to only play sound through the right speaker.
I recommend you see the bottom right of the computer screen, and look for the speaker icon. Right click the icon, and then select 'open volume control'. After doing this, make sure that all of the 'balance' bars(located at the top of 'volume control') are in the centre, and not at either side.
If this doesn't help, then I'm afraid you can only really purchase a new set of speakers, or have a fiddle with the wire, and see if there is a certain position or place the wire can be which makes both speakers work. If there is, tape the wire in a place/position which works.
Good Luck!
Posted on Aug 06, 2010
Mp3 sound doesnt sound right
The right speaker is open, a digital meter set to ohms will confirm, good/bad should measure 4.0 ohms to 8.0 ohms, if no reading it is bad.
Apr 06, 2012 | GPX HM3817DT Shelf System
Only the left speaker of my alesis m1 active 320 is working properly the one doesnt project sound unless u turn the volume up loud and take out the connection to the left speaker and the speaker doesnt...
have you tried control panel,administrive tools,computer management,device manager,system devices, syatem speaker,right click to update driver,disable,uninstall,scan for hardwarwe changes select properties to troubleshoot
hope this helps
Oct 29, 2010 | Alesis M1Active 320 Computer Speakers
No sounds from the left speaker even with the balance turned fully to the left. all connection are fine.
Check the speaker, switch the left and right ones and see if the left speaker still has no sound. If it works the speaker is bad, if it doesnt your left output is bad...
Dec 06, 2009 | Sony TA-FE370 2-Channel Amplifier
Hp pavillion dv6000 right speaker doesnt work
first check ur audio property ...if all correct then ur right speaker may be having some problem...
Dec 02, 2008 | HP Pavilion dv6000z Notebook
Speaker works only in one
No, i don't think so, but probably you audio was disconnected
Check the sound properties on control panel.
Check back connections, the power of your speakers. (bad power supply - replace)
Check your speakers on another computer
Oct 06, 2008 | Altec Lansing VS2321 Computer Speakers
Left speaker doesnt work
i've got the same speakers & have noticed that depending on the type and quality of the device that i plug them into i'll sometimes only get sound from the right speaker. i've deduced that this is due to the type of output the device offers. for example, if i plug the green tip of the cord into the headphone jack of a television with only one speaker only the right speaker will work. hope this helps
Aug 09, 2008 | Philips MMS 321 Computer Speakers
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
Gateway laptop speaker
the audio port needs to be replaced
if sound card is integrated systemboard needs to be replaced
if you have a sound card installed get it replaced.
Jun 05, 2008 | Gateway M305CRV Notebook
Dell ADA425 2 Speakers Logo
175 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
