Question about Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick pro duo 4 GB wont format - Sony 4GB Memory Stick PRO Duo Memory Card
  • Roy
    Roy Aug 03, 2010
    has the write protect tab been moved
  • 83 Answers
Hi friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
1) cd\ press enter
2) c:/>format drive letter (eg d: f: e: etc) press enter
3) read message carefully and then press y
now yours flash drive formatted
Posted on Aug 05, 2010
4 gb jumptwist
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
Dec 22, 2013 | Sony 4GB Memory Stick PRO Duo Memory Card
When you turn on the camera, message Memory stick error appears. Camera works fine with internal memory but not when using sony memory stick PRO DUO
Try to format memory stick through camera menu to solve this problem and if camera wont allow to format then try/ replace memory stick as this PRO DUO could be defective.
If another memory stick gives same problem then memory stick slot connectors could be bad and visual check by local camera repair shop is required.
Thanks.
Feb 27, 2011 | Sony Cameras
I have a Sony Memory Stick Duo Adapter with 1 GB Memory Stick Pro Duo insert. When I put in my DCR-TRV18 camera and switch it to Memory, I get Memory Stick Error on the screen
On many cameras , the picture format that you can save on memory stick is not the same that you can have by recording on tapes. It should be the same on your handycam.
You can increase memory stick to at least 2GB, that is what sony reccomends, you can test a 4 gb to 16 gb at the shop, if it works , then buy it.
However, the quality of movies grabbed on memory stick, should be far less than the one of movies recorded on tape.
Dec 27, 2010 | Sony Handycam DCR-TRV18 Mini DV Digital...
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
8 GB problem!!!!!!!!!!!!!!!!11111
I had the same prob. Just format the memory stick with windows and in the window that pops up on the third line choose 8192byte. Worked for me.
Dec 28, 2008 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory Stick Pro Duo 8GB on PsP
Two possibilities.
1. The firmware on your PSP is too old to recognise the 8GB (only recognises up to 4GB).
2. If firmware is up to date you have a fake memory stick (easy way to check is to check the info for the memory stick on your PSP if its says that MAGIC GATE is unknown rather than supported then it is fake.
The fake ones typically double compress the data so that it appears to have 8GB when in reality it does not.
Nov 15, 2008 | Sony Memory Stick PRO Duo (2GB) for PSP
MEMORY STICK 2 GB PRO DUO
format ur memory by rightclick on ur memory and choose the option format and follow few onscreen instructions,,,,
Thanking you
M. Sridhar
Oct 19, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Sony 4GB Memory Stick PRO Duo Memory Card Logo
152 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
