Question about InFocus IN3106 DLP Projector
I replaced the lamp and keeps showing the replace lamp message on touchpad
    President:
  • 567 Answers
Hi there, you should check to see if the lamp is properly fitted in position because that can be the reason why the device is not recognizing it.
Posted on Aug 03, 2010
After installing new lamp with new housing it shows Error message
I don't know whether you have taken all the precautions before replacing the lamp. Before and after the lamp replacement, lamp time has to be set. Otherwise, the projector will show error message when you switch it ON after the lamp replacement. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 30, 2014 | Office Equipment & Supplies
My stove keeps beeping and showing F1-8 on the display and telling me to call a tech. What is the problem. This slide in stove is abou 6 years old.
The F1-8 error code means that a button on the touchpad is stuck in and the touchpad needs to be replaced. The computer runs a self check on the oven several times per hour and it thinks a button on the touchpad has malfunctioned. Depending on your exact model the touchpad is a seperate peice or it has been intergrated into the control panel, so if it's seperate only it needs to be replace,if it's intergrated the whole control board needs to be replaced.
Hope this helps ya
Gene
Aug 01, 2011 | Jenn-Air Ovens
TV shut off and won't come back on. It has been showing message to replace lamp. Is the lamp the problem?
Hello
The life time of the lamp may have gone out. That is why it showed you that messege. Replace the lamp. The procedure and description of the lamp will be in its user manual. Follow it up. Replace the lamp with the original number only. OK.
Jun 25, 2011 | Panasonic PT-52LCX66 Projection Television
Can't reset lamp replacement message on a Sony KDS-50A2000. Any help is appreciated.
If lamp has been replaced then press Menu button on remote and select Settings then go to last option Lamp Replacement and follow instructions there.
TV wont show you lamp replacement message any more.
Aug 13, 2010 | Sony KDS-50A2000 50" HDTV
Infocus in3106 keeps showing me replace lamp message after i already did'it
Hello there, you need to check the lamp connection properly it may not be properly fitted into position that can be the reason you get that message.
Aug 03, 2010 | InFocus IN3106 DLP Projector
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Has a message on the swcreen that advises that the lamp needs to be replaced
When Lamp reaches to end of its life span/ working hours, dlp tv or multimedia projector shows this message to replace lamp.
Lamp replacement procedure is easy and usually mentioned in related user manual.
Let me know model and brand of your product to provide you helpful info.
Thanks.
Feb 08, 2010 | JVC Televison & Video
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
InFocus IN3106 DLP Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
