Question about Proform XP Weight Loss 620 Treadmill
My pro form 750 turns on and the screen turns off after a second
    Champion:
  • 218 Answers
Check the main harness running up to the console through the leg. unplug it and use a volt meter to test the red and black wires. You should have 9-12 vdc if you do and the console is not lighting check that the safety key is in place. If it is and it is still not coming on the console is malfunctioning and would need replaced. If there is no voltage coming through the harness then you will need to check the harness for continuity. If harness tests ok then the controller is malfunctioning and would need replaced.
Posted on Aug 12, 2010
Pro Form C500 wont turn on.
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 25, 2012 | Computers & Internet
I have a Pro Form 750 CS. It runs great, but when it running with the incline, it has a burning smell.
one of the motors is burning out or over heating .take hood off then run you will see ands smell which one is in failure
Mar 07, 2011 | Proform Exercise & Fitness
My wife entered the wrong pin number by accident on the nuvi 750. She tried turning the unit off and then back on to reset back to "enter pin" code mode however she gets the response "you must return to...
If you turn the unit off, wait about ten seconds and turn it back on, yes, it should go back to the "Enter PIN" screen. If, however, you turn it off then immediately turn it back on it will continue to tell you to return to the security location.
Jul 07, 2010 | Garmin nuvi 750 GPS Receiver
Removing the front roller on a pro-form 575TL
That sleeve has had it replacing the the front roller will cost you $102.95 plus S/H and tax or got to Treadmill Doctor and they can replace the sleeve for 49.95 plus S/H and Tax and final option you can order the kit for 29.95 Plus S/H and tax and do it yourself. they can be reached @ 1-800-750-4766
May 15, 2010 | Sears Exercise & Fitness
My belt is skipping on my Pro-Form 750
At the end of of the running belts in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 01, 2010 | Exercise & Fitness
Pro form 520 treadmill
I lost the manual to the pro-form 520. How do you tighten the belt? Where can I order a new or find the on line manual?
Oct 11, 2009 | Proform iLog 750 Treadmill
Turned the Nuvi 750 off while searching for a POI and now it will not turn back on.
Slide the power key to the left for 8 seconds plus, to reset it
or 30 seconds plus, to try calibrate the screen.
Regards.
Jun 22, 2009 | Garmin Nuvi 760 Car GPS Receiver
External VGA controller
The VGA adapter is only for use with Pocket Power Point: 1. Open a PowerPoint presentation. 2. Go to the View menu and select External VGA on the View Show On drop down menu. 3. To make the presentation display automatically, under Advance Slide choose Automatic and enter in the amount of time in seconds between slides. 4. Say OK to that screen, then go to the View menu again and select View Show and now the presentation should display on the VGA monitor in 640x480 and 256 colors.
Sep 14, 2005 | NEC MobilePro 750
Proform XP Weight Loss 620 Treadmill Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
