Question about Audiovox FPE3706 37 in. HDTV LCD Television
Hello, i have a audiovox fpe7306 and i am trying to connect it to my computer, When connected with a 15 pin vga monitor cable, the tv shows "invalid format" in the top left corner! Iam guessing that it is a setting issue with the computer, but i am not sure! Please help me out!
  • 3 Answers
Your're near the solution! Try a 1204 x 768 32 bits(true color) screen resolution on you computer. It's work for me.
Posted on Aug 03, 2010
Can i use my tv as a monitor for my home computer (Dell Optiplex 745)and if so how. I tried difrent ways and cant seam to do it.Help. Please. Chris.
The TV should have VGA input socket to connect with. if have; you can connect the TV with the computer, using a VGA to VGA cable.
VGA input socket.
VGA - VGA cable
25737496-zeccwmaoed3oumaueic5tnov-2-2.jpg http://electronicshelponline.blogspot.com/
Jun 09, 2015 | RCA Televison & Video
HP L1950 DISPLAY MESSAGE NO DVI INPUT
in this situation, there are two options. 1.The device connected to your TV via DVI cable is off. 2. DVI cable connected to the HP L1950 is burned.
if you try to connect a device to the HP L1950, it has two ways to connect:
Input Signal - Two connectors: one 15-pin mini D-sub analog VGA and one DVI-D. Try VGA them.
Apr 06, 2014 | HP L1950 Monitor
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
Atlast I got some help from the right people (Samsung)! I would like to share it with others facing the same problem:
If you are using the D-sub 15 pin jack (VGA Monitor Cable: make sure its 15 pin and NOT 14 pins), follow these steps:
  1. Make sure your TV and computer are off.
  2. Using a 15 pin D-sub (standard) video cable, connect the Video Out jack on your computer's video card to the PC In jack on the back of your TV.
  3. Using an audio cable with a min-stereo plug on one end and two RCA jacks on the other, connect the Audio Out jack on your computer to the left and right PC Audio In jacks on your TV. (Note: If you have your computer connected to separate speakers, you can skip this step)
  4. Switch on the Notebook and Adjust the Resolution (800 x 600 pixels would do). You can go to Control Panel and Adjust the screen resolution. (Keep ‘Screen Refresh rate’ at 60hz in the Monitor Settings)
  5. Switch on the TV and try to Select the Source as 'PC' (you can do this by either pressing the 'Source' button several times on your TV remote or go to the Menu - Setup and Select the 'PC' as source there).
  6. In most cases, after following the above steps, the TV would start to show 'Auto Adjusting' message and it will start showing your Desk top on the TV. But incase it doesn't work, you can do the following:
a. Mostly the problem lies with the VGA cable. Make sure you have the right one (15 pin) and its securely attached at both ends. If you are not using the right VGA Cable, it means that there is no connection between your TV and Notebook. Your TV will show 'PC' in Grey in the Source Input list (Go to ‘Menu’ from the TV remote).
b. Both your Notebook and TV should be switched off when you are connecting the cable otherwise one of them might have a problem detecting the other one.
c. Try Pressing Fn + F5, F6, F7 (depends on which Notebook brand you are using) on your Notebook several times. At times, you will see some signs that the Notebook and TV are trying to connect. Select 'CRT' from list of displays available to you.
May 09, 2008 | Televison & Video
Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Mar 08, 2008 | Televison & Video
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Audiovox FPE3706 37 in. HDTV LCD Television Logo
83 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
