Question about Garden
My weedeater starts and runs for a few seconds then shuts off, is this a fuel problem?
    Problem Solver:
  • 7 Answers
How long has it sat for?
Posted on Aug 17, 2010
27cc weedeater like new will start and run for few then stops when I give it Fresh gas and oil mixed accordingly
indicates a problem in the fuel lines to the carby
could be a hole in the primer bulb, split hose
hoses on the carby incorrectly
diaphragm problem in the carby ( real possibility if using e-mix fuel)
Aug 16, 2018 | Weedeater Garden
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
My poulan weedeater starts easy but only runs a few seconds and shuts off. Replaced the fuel tank, fuel line and spark plut.
When this happens; unscrew the spark plug and see it's condition. It can be any color, it can be wet which indicates a carburetor needs adjustment. Also the compression of the cylinder needs to be measured.
Aug 07, 2015 | Poulan Garden
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Toro weed eater starts but then stalls out
A few things to check, clean or replace:
  • fuel filter - located inside the fuel tank
  • Spark arrestor - located at muffler
  • Spark plug
  • Carburetor
Mar 08, 2014 | Garden
How to start
Full choke until it tries to start, half choke until it does, and once it's running, open the choke fully and wait a few seconds for it to warm up before using it, as well as 15-20 seconds to let it cool down before shutting it off so as not to warp any metal parts of the engine
Nov 08, 2013 | Poulan WeedEater Hedge Trimmer 25cc Engine
I have a 1987 Plymouth Voyager that starts, fuel pump comes on but it just runs a few seconds and stops. If you turn the key off and back on, the fuel pump comes back on but shuts back off in a few se
On the fuel rail will be a small round valve type thing with a rubber vacumn tube running to it ,check the tube and make sure its connected as this will stop it from running as it opens the fuel rail for the injectors
Jan 03, 2013 | Cars & Trucks
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
My sv-30 blower will not continue running.
Have this problem currently with my WeedEater SV30, and I suspect the filter fuel line has rotted off where it passes into the tank. Had exactly this problem with my cheepy trimmer and was able to replace the fuel line. Hopefully I can do the same with my SV30 blower. Seems like the gas line material does not like the ethenol in today's gasoline...
Mar 28, 2009 | Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
