Question about Kenwood Car Audio & Video
I bought my kenwood amp last night brought it back and replaced it with a new one it cuts in and out the red triangle will come on work but the amp will cut in and out its not hot yet or has no shorts in my wires any ideas?
  • 70 Answers
It might be cause there is not enough voltage going to the amp or a fuse could be bad
Posted on Aug 04, 2010
When my kenwood amp is on, should the triangle be blue or red?
Unless otherwise stated they're supposed to illuminate red
Feb 17, 2014 | Kenwood KAC9105D Car Amp
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
Red Triangle light off?
I have the same amp in my car, If it is only a month old there is a internal problem with it, It should stay on when you used a jumper wire, I installed car audio for over 40 years before i retired, End was allso Am a certified electronic (Tech) PS,One thing it is not a 2 channel amp, people mistake it for a 2 channel amp because of the for speaker terminals on them, It is a mono (Bloc) Amp ,End where people go wrong on wireing them up is buy , Having each sub hooh up seperately to it, Instead of use just one of the negative end positive terminal on it , .I no the instruction for the wireing on it are confuseing, That can cause it to shot down. Allso if you have dual voice coil subs end there not wired up properly will cause it to shot down,
Nov 08, 2012 | Kenwood Car Audio & Video
Kenwood amp red light
Red triangle is kenwood power light. Check rcas
Sep 24, 2017 | Car Audio & Video
When i turn the music up sub cut off blue light stay on red triangle cuts off
Hi, the amp is going into protect mode. You can either keep it turned down or possibly reconfigure the speaker connections for a higher impedance. If you tell be the model of your sub, I may be able to suggest a better arrangement.
There is a manual here if you don't have one: http://manual.kenwood.com/en_contents/attachDownload/6017/
May 08, 2011 | Kenwood KAC-7204 Car Audio Amplifier
Have a Kenwood KAC-9104D the red triangle is flashing
maybe when hook up something sorted and blew the sub side .I have seen it happen
Nov 27, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Kenwood KAC-9104D
Circuit City ? I'll keep that opinion to myself.
If all is properly hooked up, Check the ground wire for the amp.
Give it a tug where it is connected to the car chassis, NOT the amp,
if it moves or comes loose thats easy to fix, scrape the paint off the grounding point use a high quality ring terminal and a oversize screw with a star locknut. Also check the wiring in the box.
Subs and boxes are quite heavy. And if it's banging around, I hope you have it in a trunk, they are very lethal projectiles in a hatchback should you have a accident.
My second thought is that you may have dislocated a component , solder joint, or cracked the PC board,
When in doubt see a installer. Good luck Sumthin
Sumthin
Jun 04, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Car Audio & Video Logo
105 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
