I need my I.P. address(?) number for my linksys to be able to get on the internet with my ipod
    Guru:
  • 1,342 Answers
Go to Start, Run type cmd, click OK. When the dos window opens type ipconfig. It should list you IP address.
Posted on Apr 26, 2008
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
The internet is hooked up and everything but it wont connect wirelessly to my laptop or ipod
On your laptop.... Make sure your internal wireless device is set to "Enable" It should see the Linksys right away. That wireless device should be set to DHCP for its IP Address.
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
The DNS error on my PS3 from LINKSYS
your wireless network should be configured to NOT broadcast the SID and a WEP key. Then after entering the address of the router manually in the network setup on the PS3, you will able to obtain an ip address from the router
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
I cannot link my my Ipod to my router. What must
Make sure that the wireless network key which you are punching is right,If it's WEP key,then try putting a dollar "$" sign before you give the WEP key.
In order to re-check the wireless network key of your router,follow following steps:
1> By default ip address of all linksys router is 192.168.1.1.Open the internet browser & clear address bar at the top completely & type default gateway of yours computer which you are getting from router
2> Default username is blank & password is "admin".Otherwise give router password.Again if it is not working type default password which you usually give to your computers
3> Finally,you will be on router setup page;in top click on Wireless tab --> Wireless Security
4> Here you can re-check that your wireless network password.
If u need technical help in order to do the above changes in router have a words with linksys technical suppoprt.
Dec 08, 2009 | Linksys Wireless-G WRT54G Router
I have a i pod touch and it wont link with linksys
Well you need to check the wifi settings in your ipode. Make the same settings which you have configured in your linksys Router.
If you have enabled Mac filtering on the Linksys router then u need to add the mac address of your ipod in the list.
I think that would solve your problem.
Amit
Mar 17, 2009 | Linksys Wireless-G WRT54G Router
Ip address?????????
we need to open ports in the router...can u tell me ur isp's name
Jun 17, 2008 | Linksys Wireless-G WRT54GX4 Router
I have a Comcast cable modem (Arriss) with a Linksys router attached to a Dell PC desktop in one room. In an other room is a Dell PC laptop with a Linksys Wireless -G Notebook adapter card inserted. I am...
you will have to access the router by the ip address.
(192.168.??.??)once you log in, user name blank and password admin. you will have to set up wireless security. there are several ways and each that is selected has a brief tutorial.
Sometimes, people who are gamers or use Ipods, leave the router unsecure but limit the wireless access by mac address or by ip address so only those wireless devices gain access.
Apr 11, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
