Question about Uniden Cordless Phone
Crackling on the line - Uniden Cordless Phone
  • 1,557 Answers
Crackling on the line is water / moisture in your telephone line that causes a loose connection some were .you need to have your phone company come out and find the fault and fix it. they can not charge you for this service as it is due to there lines being worn by time.
hope this helps
please take the time to rate this repair advice. thank u
Posted on Aug 03, 2010
I have a samsung dishwasher that won't drain it makes a cracklings noise then the quick light starts flashing if I unhook the drain line and hold it lower in a bucket it will drain
If it is making crackling noises, it has water on electrics and is shorting out. Unplug it a call a technician before you have a fire.
Unhooking the drain line and lowering just allows water to flow past the pump.
samsung dishwasher Google Search
Jul 10, 2017 | Samsung Dishwashers
When I try to dial out the phone has loud crackling noise.
You have a line problem call your Telcom provider.
Feb 06, 2016 | Lands Phones
Really bad crackling sound on certain calls
if only happens on certain calls it could either be the handset itself, a week point on all corded phones is the cable between the handset and the body of the phone. whilst talking to someone on a call wiggle the cord where it enters the handset, does it crackle if not do the same where the cord enters the phone body, if no crackle likely not phone.
next select a line if you have more than 1 line note which 1 and dial 17070. this will BT autotest the line. if more than 1 line on system do same for all lines. check with your system admin if there are quick codes to select individual lines, eg dial 9 for any line or 81 for line 1 82 for line 2 etc .
if you get crackle still on 1 of the lines get your maintainer to check the lione at the cable head where lines enter building
Mar 02, 2015 | Panasonic KX-T7731 Corded Phone
I have crackling on my phone line when I make or recieve a call. The phone is new and a cordless model. Can you recomend any solutions Thanks
do you have broadband on the same line as the phone? does the broadband have filters connected to the line at the AP. Is the phone positioned beside any other electronics in the house such as microwave, tv, radio, baby monitor, washing machine, if so i suggest moving it to a more reasonable location where there are no electronics to interfere with the signal.
if crackling continues leave item back to store.
May 31, 2011 | Panasonic Lands Phones
Our fax machine is receiving faxes but won't send them. It says poor line condition. I've switched the actual line with another & it still says the same thing.
Sounds like you hve "noise" on the phone line you are using. Try plugging a normal phone into the line socket you are using for faxing, then pick up the reciever to make a call. If you hear crackling then the line is noisy and you need your phone service provider to repair the line. If you dont hear crackling try using another line lead.
Mar 04, 2010 | Brother Multi-Function Center MFC-240C...
THE PHONE LINES ARE ARE MAKING A CRACKLING SOUND, WHICH SOMETIMES MAKES IT DIFFICULT TO HEAR WHAT IS BEING SAID
Crackling and buzz can come from a few different sources. I need a few more details. Is it on all phones? Is it on all lines of all phones? Does your caller hear the crackling too?
If it's in just one phone then switch out the handset & cord to see if the problem stays with the phone or the handset. You may just need a new hand set cord.
If it's in more than one phone then the problem will need some more testing.
Feb 23, 2010 | Panasonic KX-T7050 Corded Phone
Crackling noise coming from 1 channel
sounds like you are picking up some interference first try swapping out the RCA cables you are using to connect that component. also keep your RCA cables away from any 110V AC power lines.
same thing with speaker cables, speaker wire should intersect power lines at 90 degrees and should not run parallel to power lines.
many people use the wires that come with their components. these cables are thin and offer very low performance a thicker higher quality cable with a gold connector will not only better maintain the quality of the signal being transferred between components but will also have better shielding to protect the cable from picking up interference from other electrical components and power lines.
Also should point out that a blown speaker sometimes produces a crackling sound, swap your left / right speakers and see if the crackling sound still comes from that speaker if it does you have a blown / damaged component.
Dec 30, 2009 | Onkyo Audio Players & Recorders
Excessive line crackling noise
The service manual is at www.akg.com/mediendatenbank2/psfile/datei/19/C4194055d1fa264a7.pdf. You will have to replace the wiring that goes to the cartridge through the gooseneck.
May 25, 2009 | AKG C419L Professional Microphone
Tv making a loud crackling
The set should be under warranty, call the company or go on line and get a servicer out asap. good Luck
Mar 19, 2007 | Polaroid FLM-3232 Television
Uniden Cordless Phone Logo
421 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
