Question about Samsung Cameras
I have a samsung camera but every time i try to turn it on it just makes a beep. The camera lense won't go back in. what's wrong with it.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 03, 2010
I have a samsung S500 and when I turn it on the lens doesn't open or extend and it will beep 3 times and shut off. I have tried new batteries and nothing works. I took it to a camera shop and they
Well, have you ever considered that the lenses MIGHT be defected? If it's true, you can send it back to the manufacturer, as long as it wasn't YOU who made it defected.
Another tip, is maybe the lens isn't made for that type of camera.
Lastly, the lens can just be broken, so you should carefully examine it, and see INSIDE of it, to make sure all of the parts are their. Hope this helps (:
Jun 11, 2012 | Samsung Digimax S500 Digital Camera
Zoomes lense wont come back in and the camera beeps 3 times and shuts off when you try to turn it on.
I would check the batteries and also try to reset the camera.
If that doesn't work, the camera needs to be sent back to Samsung.com for repairs.
http://www.samsung.com/us/support/online/supportOnlineServiceRequest.do
Aug 17, 2010 | Samsung SL620 Digital Camera
Camera wont let lense come out
notify SAMSUNG of your problem should have warranty
Nov 18, 2017 | Samsung TL34HD / NV100HD Digital Camera
Samsung s630
Not a solution, but empathy. I'm having exactly the same problem.
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax L730 Digital Camera
I encountered this issue today while taking a photo of my dog she licked the lens... the LCD screen went all blurry and I was unable to take any photos. The thing kept beeping at me and I was about to throw it in the bin until I had a good look at the lens. As there was a picture coming through on the LCD I knew it wasn't completely stuffed however as the camera couldn't focus an image it gives the unhelpful beeps which apparently translates to clean the lens! So i gave it a clean and presto it was fixed!
Just be careful when u clean it make sure u don't scratch the lens with rough material or use chemicals. Hope it works.
Feb 17, 2008 | Samsung Digimax L730 Digital Camera
Cameras lense open, camera off, when turned on it bleeps and turns itself off
i have exactly the same problem with exactly the same camera. It happened to me once before but by 'fiddling' with it, it seemed to catch back in place and turn on again. but this time it wont work. seems like a design fauly from samsung?
Nov 08, 2006 | Samsung Digimax V800 Digital Camera
Cameras Logo
32 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
