Question about Dell 0Y3740 Keyboard
Inspiron 6000 keyboard replacement
I unscrewed all the screws on the back but the upper section does release.
please help
  • 242 Answers
You can find how to remove your keyboard here.
You need to remove the hinge cover. Underneath it are two screws.
Good luck
Posted on Apr 26, 2008
How do I remove/replace powersupply for dellinspiron one 19 computer
the service manual for this computer (download
Product Support Dell US )
has a section titled Power Supply (link from menu on first page) which sections titled "Removing PS" and "Replacing PS"
21.February.2015
Feb 22, 2015 | Dell Inspiron One 19 All-in-One Desktop PC...
How to reset bios on compaq v2000 laptop
Remove A Cmos Battery From A Compaq V2000 Laptop
The Complementary Metal-Oxide Semiconductor (CMOS) in a computer is responsible for storing hardware settings and time on your computer. The CMOS is powered by a small battery and is able to store information whether your computer is turned on or off. While the standard CMOS battery lasts for up to ten years, you may need to replace your CMOS sooner than that. If you password your BIOS and forget the password or need to reset your configuration back to the default, you can remove the CMOS and re-insert or replace it.
Instructions
1. Unplug the computer from the wall outlet and unplug the AC adapter from the computer.
2. Turn your Compaq Presario V2000 face down and slide the battery release latch to the left to disengage the battery from its position. Remove the battery.
3. Unscrew the screws over the hard drive cover, which is located in the lower right corner of the laptop if your laptop is placed with the battery away from you. Lift the hard drive tab, located on the left side of the hard drive, and slide the hard drive to the left to remove it from the computer.
4. Unscrew the single screw located directly under the optical CD/DVD drive. Insert a very thin item, such as a paper clip or pin, into the hole located on the optical drive to open it. Slide your optical drive out of its tray to remove it.
5. Remove the two screws located on the switch cover, which is directly under the battery. Turn the computer right-side up and open it as wide as it will go. Use a flat tipped screwdriver to lift up the switch cover that is directly above the "F1," "F5," "F11" and "Insert" keys.
6. Unscrew the four screws that hold the keyboard in place. These screws are are located in the upper right corner of the computer under the switch cover that you just removed. Lift the keyboard up and slide it forward until it rests on the palm rest. Unplug the zif connector, which is located directly above the palm rest, to disconnect the keyboard. Lift the keyboard up and out of the laptop.
7. Turn the computer upside down again and remove the memory modules by unscrewing the two screws over the memory compartment located directly below the battery slot. Unclip the two clips located on each side of the memory module to release it from its slot and slide it out of the computer.
8. Unscrew the two screws on the PCI cover directly beneath the memory module. Disconnect the two wireless antennas above the card. Spread the two clips securing the mini PCI card into place and lift the card up and out at a 45-degree angle away from you.
9. Flip the laptop back up on its right side and disconnect the display cable located in the upper left corner above the keyboard area underneath the switch cover you removed earlier. Then remove the two pieces of tape in the upper right corner that hold the wireless antenna in place. Remove the two clips located beneath the tape pieces. Unscrew the two screws on the upper left corner and the two in the upper right corner that hold the display into place. Remove the display assembly.
10. Turn the computer back upside down and remove the remaining 19 screws. Lift the base enclosure straight up out of its place.
11. Locate the CMOS battery, a small circular object, and lift it up out of its place. Leave it out for five minutes and reinsert it to reset your settings. Re-assemble the computer without the battery and plug it into the wall.
Remove Cmos Battery From Compaq V2000 Laptop
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
Replace keyboard please
Manual is here
http://support.dell.com/support/edocs/systems/ins6000/en/sm/keyboard.htm#wp1111863
You can buy a replacement on Ebay
http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=inspiron+6000+keyboard&_sacat=See-All-Categories
Jun 08, 2010 | Dell Inspiron 6000 Notebook
I spilt a Milo on my keyboard. I gave it a good rinse right after it happened but now its really struggling. Basically I want help opening the keyboard. I have unscrewed the back but it wont open. Any help...
Unscrew ALL screws on the device, additionally use a kitchen knife and pry/remove the keys on the frontside if the design allows for it, though a photo or a quick sketch of the button positioning might be useful for later, check for hidden screws under the button interface.. when you are sure you stripped the keyboard of all accessible screws it will be as with opening all plastic devices.. bend and pray.
Bending open plastic devices and components is never pleasant, they are usually secured by several dead-lock mechanisms and you are likely to break a few in the process.
May 06, 2010 | Microsoft 6000 V3 Mouse
Dell Inspiron 6000 keyboard issues
Sounds like something got spilled on it and keys are sticking underneath. Keyboards are quite easy to remove. Check online for help in removing. I suggest you clean it with rubbing alcohol (after it is removed) and spray dry quickly with compressed air. If that dont help then order one online. Tons of dell parts on ebay. Good Luck.
Nov 23, 2009 | Dell Inspiron 6000 Notebook
My kid has picked the buttons off my inspiron 1525.i need a pic so i can put em back in the right place
Here is a picture of the Dell Inspiron 1525 keyboard >>>>>>>
Good luck and regards.
Aug 03, 2009 | Dell Inspiron 1525 Notebook
How do i replace the keyboard on a dell inspiron 1525
How to Install a Replacement Keyboard on Dell Inspiron 1525 Laptop Computer You may need:
  • New keyboard
  • Screwdriver
---Be careful to not break off any of the plastic tabs on the keys as they are difficult to replace.---
  1. Turn the computer off and slide the tip of the screwdriver in the notch on the right side of the hinge cover (the plastic section above the keyboard). Slide the hinge cover up and remove it from the computer, exposing a series of bolts. Unscrew the bolts and remove them.
  2. Pull up on the edge of the keyboard and slide it forward toward the display. Slide the keyboard all the way out of the computer case slowly.
  3. Unhook the flex cable from the computer board to disconnect it from the computer.
  4. Slide the new keyboard into place, connecting the flex cable first.
  5. Screw down the edge of the keyboard with the 4 bolts from before and replace the key cover.
  6. Power up the computer and see how your new keyboard works!
May 01, 2009 | Dell Inspiron 1525 Notebook
How do I put my new dvd rewritable driver in my dell laptop 1501
All of the below is from your Inspiron 1501 Manual, which if you do not have a copy, you can obtain
a PDF document Here
You will find all below under Adding and Replacing Parts--Optical Drive
Optical Drive
CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in the
ProductInformation Guide.
Turn the computer off.
Turn the computer over and remove the optical-drive locking screw.
Insert a scribe into the notch and push it to the side to release the drive from the bay.
Slide the drive out of the bay.
Apr 10, 2009 | Dell Inspiron 1501 Laptop
Electrolux contour 1100 flexihead. Z1436
You need to unscrew the screw at the back / base of the handle. The whole handle section will need to be slid backwards. Best way is to unscrew the screw on the rear approx 5 turns and then bump the end of the screwdriver. A few more turns then bump the end of the screwdriver again. The whole handle will eventually slide backwards and fall off. Then unscrew the two screws at the front (near switch) and the front switch cover plate will lift up (hinging at the top). This reveals the incoming wires etc.
Jun 18, 2007 | Electrolux Cleaner Lux 6000 Vacuum
Dell 0Y3740 Keyboard Logo
788 people viewed this question
Alun Cox
