Question about Poulan Pro 22inch 625 Series Briggs Stratton Gas Powered Side DischargeBagMulch Front Wheel Drive SelfPropelled Lawn Mower With Electric Start And High Rear Wheels PR625Y22RKP
Poulan Pro 625 Series Wheeled Trimmer How do I get the string on it and how much do I use
rtpflh
  • 546 Answers
SOURCE: where is the oil drain plug
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Posted on Sep 27, 2009
RonInFla
  • 86 Answers
SOURCE: poulan pro 625 series Will not start. I have
1st: stale fuel...won't burn...regardless of spark...
2nd: watch primer when it comes back up, it must "fill" with fuel...a tiny bubble is o.k. If not, carb replacement...
3rd: Flood to hell and back...remove the plug, pull 5 or 10 times to clear the gas...dry off plug...install...hold trigger wide open, and pull..NO PRIMER
if this works, go back and review starting procedure
8^)
Posted on Apr 17, 2010
philwalker78
  • 608 Answers
SOURCE: just looking for the type of oil I need to use for
Briggs and stratton sae 30 engine oil or any other reputable brand sae 30 engine oil is fine. Regards Phil
Posted on Apr 16, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Where is the oil plug
Hi ca rishell
The oil drain plug is under the mower, look for the pipe plug in the engine housing, be sure to remove the spark plug wire before working near the blades as a safety item...
Free Answer, Please rate me
#1 Taper
  • 1041 Answers
SOURCE: I have a poulan pro
I use Briggs & Stratton SAE 30 and it takes about a pint or a hair more.
Jim
Posted on Aug 20, 2011
How do I remove the shaft from my trimmer
String Trimmer Drive Shaft Replacement - Poulan Pro ...
? 2:18
www.youtube.com/watch?v=A_Sv1S7r_-o
Mar 4, 2013 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing the lower drive shaft on Poulan string trimmers. The .
Jul 28, 2015 | Garden
Just looking for the type of oil I need to use for my poulan pro 625 series
Apr 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
How do you wind replacement line to the Poulan Pro String Trimmer?
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How do I get the head off of the trimmer?
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Jun 20, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Renewing the cutting line
This product is driving me nuts - if someone can't help then its going into the bin
Aug 28, 2008 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan Pro 22inch 625 Series Briggs  Stratton Gas Powered Side DischargeBagMulch Front Wheel Drive SelfPropelled Lawn Mower With Electric Start And High Rear Wheels PR625Y22RKP Logo
79 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
