Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
46"toshiba regaza tv has recently developed a thick blue vertical line,which slowly disappears after half an hour.
    President:
  • 1,099 Answers
All plasma an lcd TVs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 03, 2010
The right half of the screen developes vertical lines after the tv is on for an hour
What year was the TV manufactured? What model is it?
If its manufactured in 2008 get back with me.
I have a failing LCD panel and am starting a class action lawasuit against Toshiba becuase there is a high number of failing units built during this time that Toshiba is not addressing and their customers are not being herd... well I am going to make them listen!
let me know if you want to be part of this activity.
andedwar@cisco.com
Dec 24, 2010 | Toshiba REGZA 52RV530U LCD TV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Mitsubishi 46in. LCD
The TCON board at the top of the panel is causing the issue. You will need to replace the whole panel.
When the set warms up, the TCON behaves. Replace the panel now to avoid what will eventually become a permanent line (if not several)
Jan 19, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
Tv toshiba vertical problem
I had white lines 4" thick vertically for about a week, then one day powered the unit up and with in 3 seconds there was a loud pop from the rear or the unit. Any one know what needs to be replaced?
Jan 23, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
394 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
