Question about Sony BRAVIA® DAV-HDX279W Theater System with Wireless Speakers
I tried to plug Sony DAV-HDX279W into my tv with simply plugging yellow white and red into each unit but I get no sound.
  • 1,557 Answers
Common fault make sure the red and white are in the correct plugs as most units have 5.1 suround there are 3 sets of sound outputs use LF & RF
BEST OF LUCK
Posted on Aug 03, 2010
My Sony DVD plays but there is no screen on the Sony Bravia TV. I hear the movie but no picture. The HDMI cable is plugged in. Why can't I get no picture? The TV is blank.
Make sure that you are plugged to the input of the TV and not the output. The other thing is it could easily be a bad cable. Check to make sure all cables are pushed in all the way as well. I know that sounds stupid but those are the little things that drive us all crazy but usually fix it. If none of this works let me know.
Jun 12, 2011 | Sony BRAVIA® DAV-HDX279W Theater System...
I am trying to set up my Xbox 360 to my dav c700 and I have everything plugged in and the surround ound works (well) although no video is showing on my screen. I cant work out where to plug the yellow...
First off you should switch to a high definition cord. But the yellow one will work for you. Just simply plug it into the yellow cable on the back, then switch to that input, the two sound inputs (white and red) will be next to this yellow input.
Apr 03, 2011 | Televison & Video
I've had my Sony Carousel CD player wiorking with DAV-HDX279W home theater system before. I used the TV/Video mode and it played. Now it doesn't. I can't find any setting that might have changed. ...
make sure the input is set to( analog in) on the stereo --this will enable the red and white jacks----it might have changed to digital which would enable the optical and coax jack--
Sep 05, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
On my SONY DAV-HDX279W, the module that runs the rear speakers turns itself off after just a minute or two. In other words, my surround sound system won't deliver surround sound. Is this a short? Any...
are you using the speakers that come with it? its not typically recomended to use speakers not included with your htib system due to the diffrence in nominal ohms. however if you are using the original speakers check to see that the positive and negative wires are not touching. also check to see that there are no loose or cut wires if you have taken all of these precautions then most likely your unit is over heating due to prolonged use
May 24, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
I get surround sound whenever i'm playing dvd's. But how do i hookup surround sound when just watching television? I have a 46 inch Sony Bravia LCD TV and a Panasonic SA-HT700 surround sound and HD...
just plug your satellite and dvd player in to your tv. and simply take an extra set of red, white, yellow wires and us use the red and white wires to connect fron your tv output to your surround sound system's input. now you should have surround sound for everything included local tv stations from your tv antenna
Aug 28, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony hdx279w surround
Your system should come with all the cables and connectors you need for the system. The rear speakers should plug directly into the back of the system using the speaker connectors that came with your system. If you are trying to add additional speakers then you need special connectors for that type of application. You can try www.BogueEngineering.com for special connectors. Hope that helps
Feb 12, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
High-pitched sound when using surround sound
I had the same problem, check your wires on the back of the tv and make sure your, red, yellow and white wires are in the correct holes. What kind of tv do you have, as I have an Ilo, and it has like 15 different plugs in the back, you may have to get you book out and make sure you have it in the correct hole on the back of the tv... I hope this helps....
Jan 11, 2009 | Sony DAV-SC8 System
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony DAV SC5 Home Theatre System - NO picture only sound when DVD / VCD played
Have you set the tv type (PAL/NTSC/Multi..) or the component type (RGB, YUV, etc.) suitable for your tv? If not, go to the main menu of your Home Theater System then check it out.
Apr 19, 2007 | Sony DAV-SC5 System
Sony BRAVIA® DAV-HDX279W Theater System with Wireless Speakers Logo
113 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
