Question about Poulan Garden
Repai carbuator - Poulan Garden
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
What's the firing order for a 2008 dodge avenger
or this might help better...
The cylinders are numbered from front to rear.Firing order is 1 3 4 2.Click on the links below for a better description.
http://www.autozone.com/repairinfo/repai...
Mar 03, 2015 | Dodge Cars & Trucks
How to repai nokia wh 701 headset when only one earphone is working
Aug 17, 2012 | Nokia Genuine Wh-701 Handsfree Headset...
Stihl Fs 45 backfire
Check the flywheel key. Sounds like it is sheared causing late firing.
With piston at TDC the flywheel magnets should line up with the ignition coil legs.
May 25, 2012 | Garden
1987 jr50 throttle cable to carbuator
On top of the carburator is a round cap where the cable passes through, un-screw it, remove the spring underneath, along with the piston/needle assembly. Thread the cable through the cap and then the spring, compress the spring by hand and pull the cable slack through. The top of the piston has 2 holes side by side, one larger than the other,with a narrow groove connecting the two together, thread the cable end into the larger hole and while holding it with one hand, use the other to slide the cable through the narrow groove connecting the 2 holes so the cable end is now under the smaller hole.
Mar 23, 2012 | Motorcycles
I ned repai manual to se de Emission system of a
obtainable from a local parts store or even the local library ....maby even wiki it via internet
Sep 13, 2009 | 1994 Mercury Villager
Engine does not idle well. always surging.
the nozzle is clogged.if this is a briggs engine it has a plastic carbuator on it.to clean you need to remove the gas tank and carbuator,that the screws out that hold the carb. to gas tank.inside you will find a screen covering the nozzle,carefully using a very small screw driver pop the nozzle from the carbuator.there is an o-ring holding it in.don't lose it.gently blow air both directions through the carb.replace it and start the mower up,surge should be gone now.hope this could help,if not let me know and we can try something else........................
Jun 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Performance lawn mower
if you have fuel comming from the carbuator area it is usually a flooding problem.either you pulled it to many times with the choke on,or the needle inside the carbuator is bad.to fix the first problem, pull the spark plug out,pull it about ten 10 to twelve 12 times.reinstall the spark plug.squeeze the trigger and pull again with saw in full throttle .it should start......second problem is more complacated.you need to rebuild the carbuator.......one more thing that could cause oil and fuel from carbuator is too much oil in fuel mixture.that would be the first thing i would look into......let me know if this helps.........
Jun 03, 2009 | Garden
Motor will only run with choke closed or mostly closed
Clean the main jet in carbuator.
Mar 17, 2009 | Garden
Garden Logo
53 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
