Question about Health & Beauty
I have a technique fwd it was outside and got rained on when I went out and dried it off and tried to move it the lights continuely flash and it will not do anything. What can I do to fix this.
  • drdial Aug 04, 2010
    I will check the control box for water and see if this solution works. Let you know later.
  • 2,272 Answers
In the unit there are dual motors and circuit board.Which is controlled electrically.It must have gone short due to raining and this lights are indicating this.The unit needs to disassembled and this motors and board needs to be cleaned internally then checked.If still problem the faulty part has to be replaced. Thanks.
Posted on Aug 03, 2010
Hazard warning lights activate when engine is turned off and car is parked. Any ideas please?
try pressing the hazard light button again as it may have been accidentally pressed
if that doesn't help take it to an accredited auto electrician for a proper diagnosis as there could be a problem with the immobilizer that flashes the light when activated or deactivated and is continually flashing the light outside of the hazard switch circuit
Mar 01, 2016 | Replacement 2008 Audi Tt Single Fan Oe...
What causes CEL to flash for 1/2 mile and then go off and then not start at all after rain but start when dry?
The check engine light flashes when there is a catalytic convert damaging advent happening , like for a sever misfire . When a vehicle has a misfire problem no combustion happens in that cylinder dumping raw fuel into the catalytic convert , were it burns causing the substrate to melt . To buy a new converter could cost up to a $1,000.00 bucks ! You don't say what make ,model an year vehicle you have , so I can't say what could be wrong ! Plug wires , coil's , distributor cap if yours has one . If you have it check for DTC'S - diagnostic trouble codes , You probably have a P0300 random misfire or a P0301 - to P0308 depending on the number of cylinders Check Engine Light On
Sep 18, 2015 | Cars & Trucks
On 2003 Kia Sedona, when there is moisture outside like rain or snow the signal lights don't work Properly. When apply brake right signal light comes on and does not blink, when turn on left signa
sounds like you are getting water into the connections and possibly have a bad earth connection. Suggest you check all light connections for water ingression.
Aug 11, 2017 | 2003 Kia Sedona
Blinking dashboard lights
Try to let things dry off before panicing...water splashed everywhere!
Jan 13, 2013 | 2002 Hyundai Elantra GT
I was using my camera outside, in abnormal conditions (rain), then suddenly the screen went blank with the camera still switched on.
If you put the camera in rice, or some other desiccant, and leave it for at least several hours, with the battery removed, that will help dry it out. It would be best to disassemble it and clean the circuit boards with denatured alcohol.
Jan 30, 2018 | Samsung Digimax i6 PMP Digital Camera
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
I have Panasonic KX-T7420s with a TVS50. I have voice mail set up at each extension number. I tried calling from an outside number and transferring to a different extension number to see if I can leave...
Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE rings....you should adjust that to no more that 4.
Car
Dec 27, 2010 | Panasonic KX-T7420 Corded Phone
My Samsung guru 100 mobile is giving continuous beeps.
you can try drying the unit out: carefully take the casing apart until the inside circuits are exposed and let it sit for 24 hours. you can also try using a hair drying on the lowest setting to help speed up the process. however, with water damage, it's pretty much hit or miss on whether it can be repaired outside of having the damaged receptors replaced.
Mar 19, 2010 | Cell Phones
Engine light flashes, then steady, and car is
usually when the engine light flashes that means you could be damaging the catalytic converter go somewhere to get codes checked with scanner
Sep 22, 2009 | 2003 Ford Crown Victoria
2004 mazda rx8 cranks but won't start
Sounds like you flooded it not with water but with fuel due to moving car with out warming it up all the way before shutting it off. You can take it to the dealer and get a flash update to prevent this in the future. To deflood remove spark plugs and let sit with fan on them over night to dry out. Replace and start cranking for 15 seconds at a time till she starts up. GL!
Mar 21, 2009 | 2004 Mazda RX-8
Health & Beauty Logo
21 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
