Question about Sony Ericsson HBHPV708 708 Bluetooth Headset Dark
Sony Ericsson HPH PV708. Everytime I press a button, the light is just continually red. I have tried to reset it by pressing the volume keys, but nothing happens. I am unable to clear this red light off it so that I can connect it. I read on a forum that I could remove the battery, but I dont know how to do this. any help at all please?
SOURCE: Sony Ericsson K800i
i charge my se k880i, the reslut is the battery gets hot, but not full charge and when i open the phone it will no open, is it true that se phones have no available spareparts and is expensive?
Posted on Dec 12, 2007
SOURCE: Sony Ericsson W900i Pairing With HBH-608
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
Posted on Jan 13, 2009
sabharish
  • 297 Answers
SOURCE: My Sony Ericsson W380i won't come on. The key pads
You have to reinstall the Phones' software for such problems...it happens in all SE phones..Give it to the nearest SE services center and they do it less than an hour.
Posted on Mar 28, 2009
shastalaker7
  • 1515 Answers
SOURCE: hbhpv708 when i press any
Hi, Before any bluetooth will connect to any phone, the red or red and blue light must flash back and forth. Make sure you're phone is in the set-up mode to recognize the phone. The easy way to do this if you dono't have directions, is to get the name and numbers off of the bluetooth and go online to find it. It will walk you through the steps to connect it to your phone. I have done this with many different models if all else fails. Give it a try and let me know what happens. This will solve you're problem,
Shastalaker7
Posted on Jan 29, 2010
SOURCE: Master reset HBH-PV702
How to restart my hendsfree? pls answer me, i can connect it with no one
Posted on Jun 07, 2010
How do i format my xperia?
Hi Laila,
To factory reset your phone you will need to do the following:
Press and hold Camera key + volume up key+ power button together
The phone will format itself to factory default, if this does not work then you will need to navigate to:
Setting -> Privacy -> Factory data reset -> Reset phone -> Erase everything.
Please let me know if this helps,
Thanks,
Hunter Quinn
IBM Technician
Jul 15, 2014 | Sony Ericsson Sony Xperia Sola Red, 8gb,...
Tip
How to reset Kyocera Zio m6000
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
To reset Kyocera Zio try the following:
1. Remove battery and put it back after two minutes
2. Press and hold down the home button key while turning on the phone.
3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
If it does not work, try:
Hard reset 2.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If still no luck, call Kyocera directlyand report the problem.
on Sep 03, 2010 | Cell Phones
I forgot my unlock pattern to my Polaroid Tablet
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Oct 31, 2013 | Sony Ericsson XPERIA X10 Cell Phone
Red light on my sony w995 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 25, 2012 | Sony Ericsson Walkman® W995 Cell Phone
How to unlock j108i
Hi, You can unlock a Sony Ericsson J108i safer and easier using unlock code. you can get the unlock code for a Sony Ericsson J108i from www.onlinegsmunlock.com/sony-ericsson-j108i/rs7wp9/ at affordable cost.
UNLOCKING STEPS FOR SONY ERICSSON J108i
1 - Switch ON your Sony Ericsson J108i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
Oct 06, 2012 | Sony Ericsson J108i Cedar black/red...
My sony ericsson w995 wont turn on
5.Wait 10 seconds.
Step
Thanks
Sep 17, 2012 | Sony Ericsson W995 Cell Phone
Sony xperia ion troubleshooting
The phone have a battery issue.
Replacing battery is the only solution.
Nov 01, 2017 | Sony Ericsson Cell Phones
How do I reset my sony ericsson xperia e15I
how to reset sony ericsson e15i
May 13, 2011 | Cell Phones
Parrot memory full
I had same problem too.
I have googled 3 days and found the solution from MULTICAN manual.
•Reset the hands-free kit:
Repeat the following sequence five times:
press the "Volume (-)" button and then the "Volume (+)".
And also F.Y.I.
•Enter the menu:
Press the following sequence twice: [SEEK up] button then the [SEEK down] button.
•Go forward through the menu: Press the "Volume (+)" button.
•Go backwards through the menu: Press the "Volume (-)" button.
•Select a menu option: Press the "Phone" button.
•Cancel a function: Long press of the "Phone" button.
Jan 18, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Pairing
1) Make sure headset is off. 2) Press and hold the answer button until the light flashes green and red. 3) If it only flashes green, press and hold both volume buttons until the light lashes red and green. 4) It is now ready to pair: follow the instructions in the bluetooth menu of your phone. When asked for the passcode enter 0000. 5) All done.
Feb 24, 2007 | Sony Ericsson Universal Bluetooth...
Sony Ericsson HBHPV708 708 Bluetooth Headset Dark Logo
Top Sony Ericsson Radio Communications Experts
JonSnell Electronic
JonSnell Electronic
sandrasteven
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
